Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Samsung > Samsung Hardware Repair Area
Samsung Hardware Repair Area Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 02-26-2005, 04:17   #46 (permalink)
Member: 56863
anyone got X430 cannot on and X430 ringtone fast solution ?
The Following User Says Thank You to glhs For This Useful Post:
Old 02-26-2005, 04:22   #47 (permalink)
desmond2727's Avatar
Member: 58704
Sonork: 100.1618753
e700 after changing flex cable front lcd no light???
Hi mate i hv problem to that E700 after chargin flex cable front lcd no light then evrything work well jst no light
Old 02-26-2005, 04:23   #48 (permalink)
Member: 58704
Sonork: 100.1618753
Hi mate try to replace that buzzer ic..
The Following User Says Thank You to desmond2727 For This Useful Post:
Old 02-26-2005, 04:28   #49 (permalink)
Member: 103114
thanks gr8 work
bakry .....
Old 02-26-2005, 13:24   #50 (permalink)
Member: 51305
sorry acyl2000 i didn't know that other language are not allowed
Old 02-26-2005, 23:45   #51 (permalink)
ndagi's Avatar
Member: 18926
Sonork: ndagi
Good??
Excellent My Brother Just Slendid! Wish They'd Be More Like You Around Here!
Hail Eminem!!!
Old 02-27-2005, 14:18   #52 (permalink)
COMPAQ's Avatar
Member: 18462
good work man can u pls tell us the r220 ltrg substitution....with a diode
Old 02-27-2005, 15:47   #53 (permalink)
sevgigsm's Avatar
Member: 81576
t500 lcd repair
Originally Posted by haidour
repair T500 display
ReGarD HaiDour
T500 lcd repair
no camera repair in lcd repair
orj picture sevgigsm
to take pains with sevgigsm
respectttttttttt
regard
The Following 2 Users Say Thank You to sevgigsm For This Useful Post:
Old 02-27-2005, 16:14   #54 (permalink)
Member: 72851
@all
I got a C100 already convert to C108 firmware is there anyway to convert ...
I already try all flasher...
Is there any solution ??
Old 02-28-2005, 06:40   #55 (permalink)
EMINEMGSM's Avatar
Member: 57652
Thumbs up X450 Mic solution
X450 Mic solution
Thx to Pepic
The Following 13 Users Say Thank You to EMINEMGSM For This Useful Post:
Old 02-28-2005, 06:47   #56 (permalink)
EMINEMGSM's Avatar
Member: 57652
X450 keypad solution
Thx to Pepic
The Following 8 Users Say Thank You to EMINEMGSM For This Useful Post:
Old 02-28-2005, 07:21   #57 (permalink)
EMINEMGSM's Avatar
Member: 57652
C100 charge paused by temperature
remove (U202)
and then replace it 'Look at the first shem UP' !
thx to YASSINOV
The Following 11 Users Say Thank You to EMINEMGSM For This Useful Post:
Old 02-28-2005, 16:57   #58 (permalink)
Member: 76801
[QUOTE=uqbah]i have tested this solution works 100%
put the samsung charger in while u only have board in your hand.
start to short the power ic (just above sim jacket)legs from lower left corner and move to the right corner at one point key pad lights will enlighted your phone is on now.......
as shown in the figer[/QUOTE
is what you pouver to explain me well your method it is not very clear
Old 02-28-2005, 22:11   #59 (permalink)
forhike's Avatar
Member: 14934
Originally Posted by EMINEMGSM
SOLUTION for X600 hang and restart
thx to nobal1976
hehe i'm taking back what i did wrote before phone went crazy 5 minutes ago
Old 03-01-2005, 10:17   #60 (permalink)
Member: 64680
x600 full range but no calls
Hi,
phone had broken lcd, after replacing it has full range but it makes no calls. I found that two capacitors near the oscillator (26 MHz?) are broken (those are little two from the side of the board). Can anybody post a photo of that area of the working phone?
Regards,
Tomasz WL
_________________________________________________
I found the solution: upper one was resistor R139 (1k), lower one was capacitor C154 (10pF). Damn' I'm good
***All Samsung Hardware Solution*** nafisd Samsung Hardware Repair Area 4 02-25-2013 10:26
***All Samsung Hardware Solution*** bunty2008 Samsung Hardware Repair Area 28 01-12-2013 04:24
All Samsung Hardware Solution bsat Samsung Hardware Repair Area 16 08-04-2012 12:32
Page generated in 0.26271 seconds with 12 queries
