Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
View Poll Results: Did this solution solve your "Insert Sim" on E710 ?
Yes, it was solved 237 55.76%
No, it was not solved, still showing "Insert Sim" 115 27.06%
I want to see another solution for this problem in this thread 109 25.65%
I dont care, never had this phone 63 14.82%
Thankyou, thankyou thankyou, This one for thankyou posters only 113 26.59%
Multiple Choice Poll. Voters: 425. You may not vote on this poll
Old 05-30-2005, 23:46   #1 (permalink)
GSM Coolhawk's Avatar
Member: 7751
Thanks Meter: 74
Hardware Repair Series - Samsung E700-E710-E715 insert SIM Solution
@All
Well for quite some time I have not posted any solutions, due to alot of facts which I wont go into details on now
Anyway today we gonna solve the E710 "Insert SIM" fault, very easy to repair.
Tools needed for this fix :
1 : Soldering Iron 30 - 50 Watt with SMD tip.
2 : Good flux, I recommend ERSA - FMKANC32-005 non-clean cream.
3 : Soldering tin 1.5 - 2 mm with core flux.
4 : Thin patch wire insulated !
The problem occurs normally around the IC called U100, the function is actually power module/led driver and RS232 between the Sim Reader and CPU !
I've had too many with broken lines from Sim Reader to U100
Lets fix the bugger
Here you see the area we have to work on, to find the correct leg, start from top left side of U100 and start counting counter clockwise untill you reach leg 48-49-50 and 51, you can see in this picture where the pacth wire is located so you have an idea where it is
On the next pic here you see the "work area" magnified to 60x. Now the red numbers corresspond to U100 leg numbers, while THIS CYAN is what legs on the SIM Reader they are connected to
On the last pic here you see the SIM Reader legs and their numbers, in red you have the leg numbers on U100, so just measure if you have all 4 lines ok, if not you have found the fault
Well thats it for this time
More coming up soon in Samsung hardware repair area
Hope this helps out some folks. Good luck, and dont blame me for busted boards, do this at you own risk !
And please, do not start any "send me too" posts of any kind, they will be deleted. I do not have it whatever it might be. For your information I use a Novex AP-8 stereo microscope, and pictures posted here is taken with a QX3 Intel (tm) digital toy microscope, you can find those nice little ones on Ebay for around 60 Euro.
OBS ! Edit 16/9-2005
Solution for E700 will come as soon as I get a E700 board and can take some pictures. Power supply IC here is called U400, and have a different wirering..
And please, DO NOT start 1 line thank you posts, I WILL delete them, its waste of our server space, post only if you have anything additional which is directly related to this fault, or if you have found other solutions than this.
You may rate the thread instead of posting thankyou post or you can choose to make a vote on the poll on top of this page !
Regards
The Following 31 Users Say Thank You to GSM Coolhawk For This Useful Post:
Old 06-01-2005, 20:16   #2 (permalink)
Jani-Jan's Avatar
Member: 19737
Thanks Meter: 133
What is solution for E715 insert sim ?
The Following 6 Users Say Thank You to Jani-Jan For This Useful Post:
Old 06-04-2005, 16:43   #3 (permalink)
Member: 7751
Thanks Meter: 74
@Jani-Jan
Have you opend the phone and checked if same module is used ? I've been told this solution here works on E710 also, but I do not have schematics for E715 as of yet, if anyone have, let me know by email or PM, or post in this thread here.
Regards
*Edit*
It's now confirmed. This solution will work on the follwing models. E700-E710 and E715, all have the same U100 chip and wirering !
Regards
The Following 6 Users Say Thank You to GSM Coolhawk For This Useful Post:
Old 06-10-2005, 15:51   #4 (permalink)
Member: 116196
Thanks Meter: 21
hi mr gsmcoolhawk
im posted here 3 pic for e715
i hope to help any one to solv this problem
The Following 21 Users Say Thank You to elsamady-gsm For This Useful Post:
Old 06-11-2005, 13:57   #5 (permalink)
Cheater -Don't Deal with him-
abbeydguru's Avatar
Member: 23994
Thanks Meter: 43
Talking
I believe a good solution for E715 will come with time. GSM Coolhawk had already given us a clue. So let us continue researching.
The Following 7 Users Say Thank You to abbeydguru For This Useful Post:
Old 06-11-2005, 15:11   #6 (permalink)
Member: 7751
Thanks Meter: 74
@abbeydguru
Please READ full post before you post. The name of this thread is "Hardware Repair Series - Samsung E700-E710-E715 insert SIM Solution"
E715 can be repaired same way as E700 and E710, also see that I have a edit in my post just above, where it clearly states E715 can be repaired same way !
Regards
The Following 5 Users Say Thank You to GSM Coolhawk For This Useful Post:
Old 07-09-2005, 01:04   #7 (permalink)
GSM SNIPER's Avatar
Member: 27291
Thanks Meter: 81
E71x SIM reader ways
here is shared the E71x SIM reafer ways
The Following 14 Users Say Thank You to GSM SNIPER For This Useful Post:
Old 07-09-2005, 12:44   #8 (permalink)
EMINEMGSM's Avatar
Member: 57652
Thanks Meter: 1,893
Good solution
tested by me and work 100%, i have good luck to have one e715 insert sim and now repaired
The Following 4 Users Say Thank You to EMINEMGSM For This Useful Post:
Old 07-27-2005, 17:53   #9 (permalink)
Member: 132672
Thanks Meter: 11
E700 Insert Sim
Pls any Solution E700 Insert Sim. this board power i/c is U500.
The Following 7 Users Say Thank You to vince257 For This Useful Post:
Old 07-27-2005, 20:18   #10 (permalink)
eko
eko's Avatar
Member: 30098
Thanks Meter: 29
Have you tried this solution and it did not work for you??
The Following 4 Users Say Thank You to eko For This Useful Post:
Old 07-28-2005, 04:06   #11 (permalink)
Member: 132672
Thanks Meter: 11
hi eko
Thank's Reply
yes i tried the solution aldy. but the power i/c is BGA (U 500) not same U 100.
sorry my Board is E700A
The Following 4 Users Say Thank You to vince257 For This Useful Post:
Old 07-31-2005, 13:07   #12 (permalink)
hitibiti's Avatar
Member: 24023
Sonork: 100.61317
Thanks Meter: 2,630
good solution for E 700 , but what about V200 any one have solution for insert SIM Solution ?
Thx
The Following 4 Users Say Thank You to hitibiti For This Useful Post:
Old 08-16-2005, 06:59   #13 (permalink)
Member: 4627
Sonork: 57528:debeliamark
Thanks Meter: 1,034
Solution will work until have not problems between power IC and Agere CPU lines so 90% with "user" hardware damaged SIM sockets can be maded with GSM Coolhawk solution... another 10% with break between power IC and CPU need more work.
The Following 5 Users Say Thank You to debeliamark For This Useful Post:
Old 09-12-2005, 09:14   #14 (permalink)
Member: 58822
Thanks Meter: 12
lol
e700 not agere system and have no agere power ic.
so it's not for e700
The Following 6 Users Say Thank You to proffee_central For This Useful Post:
Old 09-14-2005, 19:04   #15 (permalink)
iki
iki's Avatar
Member: 61851
Sonork: 100.1604862
Thanks Meter: 117
the same is for me.I have u500 power supply,how to make this work with u500?
regards
The Following 5 Users Say Thank You to iki For This Useful Post:
Samsung E350e insert sim solution sweix Samsung Hardware Repair 1 07-03-2008 20:50
E715 insert sim message verse1965 Trident/AGERE Platform 3 11-04-2004 05:39
E715 Insert Sim EMINEMGSM Samsung Hardware Repair 2 10-29-2004 16:58
Samsung e700 and e715 cs55 Wanted Products 0 06-19-2004 10:12
Page generated in 0.30608 seconds with 11 queries
