Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| Samsung Hardware Repair Area Post here your Hardware Repairing Hints or Problems with Samsung Phones. |
| View Poll Results: Did this solution solve your "Insert Sim" on E710 ? | |||
Yes, it was solved | | 234 | 55.85% |
No, it was not solved, still showing "Insert Sim" | | 113 | 26.97% |
| I want to see another solution for this problem in this thread | | 107 | 25.54% |
| I dont care, never had this phone | | 62 | 14.80% |
| Thankyou, thankyou thankyou, This one for thankyou posters only | | 111 | 26.49% |
| Multiple Choice Poll. Voters: 419. You may not vote on this poll | |||
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2001 Location: United Arab Emirates, Dubai Age: 41
Member: 7751 Status: Offline Thanks: 2
| Hardware Repair Series - Samsung E700-E710-E715 insert SIM Solution @All Well for quite some time I have not posted any solutions, due to alot of facts which I wont go into details on now ![]() Anyway today we gonna solve the E710 "Insert SIM" fault, very easy to repair. Tools needed for this fix : 1 : Soldering Iron 30 - 50 Watt with SMD tip. 2 : Good flux, I recommend ERSA - FMKANC32-005 non-clean cream. 3 : Soldering tin 1.5 - 2 mm with core flux. 4 : Thin patch wire insulated ! The problem occurs normally around the IC called U100, the function is actually power module/led driver and RS232 between the Sim Reader and CPU ! I've had too many with broken lines from Sim Reader to U100 Lets fix the bugger Here you see the area we have to work on, to find the correct leg, start from top left side of U100 and start counting counter clockwise untill you reach leg 48-49-50 and 51, you can see in this picture where the pacth wire is located so you have an idea where it is ![]() On the next pic here you see the "work area" magnified to 60x. Now the red numbers corresspond to U100 leg numbers, while THIS CYAN is what legs on the SIM Reader they are connected to ![]() On the last pic here you see the SIM Reader legs and their numbers, in red you have the leg numbers on U100, so just measure if you have all 4 lines ok, if not you have found the fault ![]() Well thats it for this time ![]() More coming up soon in Samsung hardware repair area Hope this helps out some folks. Good luck, and dont blame me for busted boards, do this at you own risk ! And please, do not start any "send me too" posts of any kind, they will be deleted. I do not have it whatever it might be. For your information I use a Novex AP-8 stereo microscope, and pictures posted here is taken with a QX3 Intel (tm) digital toy microscope, you can find those nice little ones on Ebay for around 60 Euro. OBS ! Edit 16/9-2005 Solution for E700 will come as soon as I get a E700 board and can take some pictures. Power supply IC here is called U400, and have a different wirering.. And please, DO NOT start 1 line thank you posts, I WILL delete them, its waste of our server space, post only if you have anything additional which is directly related to this fault, or if you have found other solutions than this. You may rate the thread instead of posting thankyou post or you can choose to make a vote on the poll on top of this page ! Regards Last edited by GSM Coolhawk; 09-16-2005 at 10:54. |
| The Following 31 Users Say Thank You to GSM Coolhawk For This Useful Post: | ::-Azhar Communications-::, abid786, abidjon, abo ghazaly, abousalma007, arunad, asep yana, bobbby, bob_2, damha2nd, DouglasDou, fahadhanif, farhad 309, hamada_2back, Hamzeh Aref, imedtunisia, jhonson, jhuno, kaleem munir, layek, mercan2727, mohiuddin69, mort83, Muhammad Zakria, pswain, raagavan, riazit, sanjay_patel, silentbaba, singhdeep, tunjay-gsm |
| | #2 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2003 Location: GMT +5 Age: 38
Member: 19737 Status: Offline Thanks: 200
| What is solution for E715 insert sim ? Last edited by GSM Coolhawk; 06-02-2005 at 14:18. |
| The Following 6 Users Say Thank You to Jani-Jan For This Useful Post: |
| | #3 (permalink) |
| @Jani-Jan Have you opend the phone and checked if same module is used ? I've been told this solution here works on E710 also, but I do not have schematics for E715 as of yet, if anyone have, let me know by email or PM, or post in this thread here. Regards *Edit* It's now confirmed. This solution will work on the follwing models. E700-E710 and E715, all have the same U100 chip and wirering ! Regards Last edited by GSM Coolhawk; 06-10-2005 at 16:22. |
| The Following 6 Users Say Thank You to GSM Coolhawk For This Useful Post: |
| | #4 (permalink) |
| Crazy Poster ![]() ![]() ![]() Join Date: Feb 2005 Age: 40
Member: 116196 Status: Offline Thanks: 0
| hi mr gsmcoolhawk im posted here 3 pic for e715 i hope to help any one to solv this problem Last edited by elsamady-gsm; 06-12-2005 at 03:29. |
| The Following 21 Users Say Thank You to elsamady-gsm For This Useful Post: |
| | #5 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2003 Location: Lagos Nigeria
Member: 23994 Status: Offline Thanks: 0
| Quote:
| The Following 7 Users Say Thank You to abbeydguru For This Useful Post: |
| | #6 (permalink) |
| @abbeydguru Please READ full post before you post. The name of this thread is "Hardware Repair Series - Samsung E700-E710-E715 insert SIM Solution" E715 can be repaired same way as E700 and E710, also see that I have a edit in my post just above, where it clearly states E715 can be repaired same way ! Regards |
| The Following 5 Users Say Thank You to GSM Coolhawk For This Useful Post: |
| | #7 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2003 Location: Bled lekhla
Member: 27291 Status: Offline Thanks: 827
| E71x SIM reader ways here is shared the E71x SIM reafer ways |
| The Following 14 Users Say Thank You to GSM SNIPER For This Useful Post: |
| | #8 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2004 Location: GSMHOSTING Age: 32
Member: 57652 Status: Offline Thanks: 2
| Good solution tested by me and work 100%, i have good luck to have one e715 insert sim and now repaired |
| The Following 4 Users Say Thank You to EMINEMGSM For This Useful Post: |
| | #9 (permalink) |
| Junior Member ![]() Join Date: Apr 2005 Age: 32
Member: 132672 Status: Offline Thanks: 0
| E700 Insert Sim Pls any Solution E700 Insert Sim. this board power i/c is U500. |
| The Following 7 Users Say Thank You to vince257 For This Useful Post: |
| | #10 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2003
Member: 30098 Status: Offline Thanks: 0
| Quote:
| The Following 4 Users Say Thank You to eko For This Useful Post: |
| | #11 (permalink) |
| hi eko Thank's Reply yes i tried the solution aldy. but the power i/c is BGA (U 500) not same U 100. sorry my Board is E700A |
| The Following 4 Users Say Thank You to vince257 For This Useful Post: |
| | #12 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2003 Location: Micro-Box in Tunisia Age: 33
Member: 24023 Status: Offline Sonork: 100.61317 Thanks: 128
| good solution for E 700 , but what about V200 any one have solution for insert SIM Solution ? Thx |
| The Following 4 Users Say Thank You to hitibiti For This Useful Post: |
| | #13 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2001 Location: Bulgaria
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks: 51
| Solution will work until have not problems between power IC and Agere CPU lines so 90% with "user" hardware damaged SIM sockets can be maded with GSM Coolhawk solution... another 10% with break between power IC and CPU need more work. |
| The Following 5 Users Say Thank You to debeliamark For This Useful Post: |
| | #14 (permalink) |
| Insane Poster ![]() ![]() ![]() Join Date: Mar 2004 Age: 8
Member: 58822 Status: Offline Thanks: 1
| lol e700 not agere system and have no agere power ic. so it's not for e700 |
| The Following 6 Users Say Thank You to proffee_central For This Useful Post: |
| | #15 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2004 Location: Skopje , Macedonia Age: 29
Member: 61851 Status: Offline Sonork: 100.1604862 Thanks: 122
| Quote:
the same is for me.I have u500 power supply,how to make this work with u500? regards | |
| The Following 5 Users Say Thank You to iki For This Useful Post: |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Samsung E350e insert sim solution | sweix | Samsung Hardware Repair Area | 1 | 07-03-2008 20:50 |
| E715 insert sim message | verse1965 | Trident/AGERE Platform | 3 | 11-04-2004 04:39 |
| E715 Insert Sim | EMINEMGSM | Samsung Hardware Repair Area | 2 | 10-29-2004 16:58 |
| Samsung e700 and e715 | cs55 | Wanted Products | 0 | 06-19-2004 10:12 |
