02-26-2018, 20:53 | #1 (permalink) |
Junior Member Join Date: May 2011
Member: 1581456 Status: Offline Sonork: malkof_001 Thanks Meter: 0 | Help for lines for charging galaxy note 8 Could you help me with the tracks where the voltage passes in a note 8 SM-n950? I'm trying because it does not load or synchronize, I've tried another load port and it's still the same fault, so I ask for your help to know what components it passes through to proceed to test and reach the fault. I hope you can help me. Thank you |
02-26-2018, 21:46 | #3 (permalink) |
Member: 1581456 Status: Offline Sonork: malkof_001 Thanks Meter: 0 | the phone power on, but dont charge, the phone works only that it does not charge the battery, the battery charges it with other equipment since the pin out of the batteries is still the same, the problem is that I can not find why it does not charge and syncro |
02-26-2018, 21:55 | #5 (permalink) |
Insane Poster Join Date: Jul 2006 Location: DE_PL_CZ Age: 42
Member: 305873 Status: Offline Thanks Meter: 17 | Insert TA / USB Charging Sequence Start VBUS_IF_5P0(C860) = 5V or 9V --> NO --> Replace SUB PBA YES Check the CHG_IN_5P0(C859)=5V or 9V --> NO --> Replace U805 YES Battery is Charging? --> NO --> Replace U7018 |
The Following User Says Thank You to waliko2003 For This Useful Post: |
03-06-2018, 18:41 | #9 (permalink) |
Member: 1581456 Status: Offline Sonork: malkof_001 Thanks Meter: 0 | i have a question, the lines for usb charge and the wireless charge are the same? or its a independient line on they are different for each type of recharge? |
