03-23-2017, 17:46 | #1 (permalink) |
Junior Member Join Date: Mar 2017
Member: 2698795 Status: Offline Thanks Meter: 1 | Help me,, Samsung J7 Prime SM-G610F is Dead :( when i pressed ON button not working ,,charging not work ,, i try to open the battery and charging manual,,the battery is OK,, but when i try use Power Supply with 3,8V ,,indicator Ampere up to 0.02 A,, then i press ON button still stuck in 0.02 and not working,, please help me for the sollution what can i do it |
03-24-2017, 02:22 | #2 (permalink) | |
No Life Poster Join Date: May 2011 Location: gsm-forum
Member: 1573913 Status: Offline Sonork: hardware illustration Thanks Meter: 7,629 | Quote:
samsung sm-G610F not power on try rehot or replace power ic U5002 if it is still as before the latest firmware upgrade | |
The Following 5 Users Say Thank You to d-Artigo For This Useful Post: |
03-24-2017, 03:46 | #3 (permalink) | |
Member: 2698795 Status: Offline Thanks Meter: 1 | Quote:
thanks for it,, ok,, first steep..i will try to rehot the ic power,, if it is still as before,,i will replace and change ic power,,but if i will replace that..what No Code for the Ic power ?? i cant read it because i dont have a microscope,, thanks so much .. and sorry for my bad english ,, i come from Indonesia ,,heheheh | |
03-08-2018, 08:52 | #5 (permalink) | |
Freak Poster Join Date: Sep 2015 Location: UAE
Member: 2461303 Status: Offline Thanks Meter: 65 | Quote:
09-15-2018, 06:01 | #12 (permalink) |
Junior Member Join Date: Sep 2018
Member: 2865333 Status: Offline Thanks Meter: 0 | Hello guys. i have this weird problem i ve got samsung j7 prime water damaged that had previous worked on(the water never got to the top half of the board). i ve connect it to power supply and it was drawing 0.05ma i noticed a bad looking cap near charging port. removed the cap and now the short is gone. but when i try to connect the two antennas to power it on its not drawing anything no mater how long i connect it. where to check if the cpu gets to signal from the power button to send it to power ic ? the service manual dont show it. really appreciate if anyone can help or show me a picture. i tried reflow the charging ic and power ic nothing happens. what would you suggest to do ? Thank you ❤ Last edited by JosephHB; 09-15-2018 at 06:06. |
06-27-2021, 04:48 | #13 (permalink) |
Junior Member Join Date: Jun 2021 Location: Ph
Member: 2990401 Status: Offline Thanks Meter: 0 | hi sorry to revive old thread i have a samsung j7 prime duos. i had it repaired and now the unit cannot connect to pc. (device has malfunctioned in windows) red indicator light will not turn green even if battery percentage is 100% also battery drains itself very fast. What do i have to check? before repair everything was working fine. Before repair, unit was low on battery until the unit shut it self down. when trying to charge not charging won't turn on. |
