12-17-2017, 11:09 | #1 (permalink) |
No Life Poster Join Date: Dec 2011
Member: 1704666 Status: Offline Sonork: 100.1652565 Thanks Meter: 157 | how to fix samsung G355h/ds charging paused battery temperature too high solution |
12-17-2017, 11:25 | #2 (permalink) | |
No Life Poster Join Date: May 2011 Location: gsm-forum
Member: 1573913 Status: Offline Sonork: hardware illustration Thanks Meter: 7,629 | Quote:
Thermistors are temperature sensing elements made of sintered semiconductor materials to show a large resistance change proportional to small temperature changes. This resistance can be measured by using small direct current and measured, or dc, through the thermistor to measure the resulting voltage drop. This solid state temperature sensor actually functions like a temperature sensitive resistor. From there the name, a clear combination of the word thermal and resistor, comes from. Ametherm specializes in NTC, or negative temperature coefficient, thermistor. Thermistors are a very accurate category of temperature sensors on the phone nokia = Btemp ....... in samsung = ntc thermistor with code: 1404-00XXXX | |
The Following User Says Thank You to d-Artigo For This Useful Post: |
