08-17-2015, 16:48 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: PAKISTAN
Member: 585807 Status: Offline Thanks Meter: 781 | How to remove emmc ic and how to put repair or new emmc emmc pinout acording to picture . many member woried pinout emmc destry when removed. but dont woried some point not use in emmc.now methed for remove emmc 1.1st use little heat for removed glue 2.if handset is i9300 then remove glue baseband ic and cpu only side emmc. 3.use hot air little heat and air.then you give heat emmc use sharp tussar for removed glue emmc under. 4.you must remove emmc in 5th mint 5.after removed emmc we want very very clean emmc point if not clean pinout you dont get baseband i mean imei so clean very much. 6.now you want old or new emmc put on board 7.when you put new or old emmc must heat and air little. little mean if you put soldring past(flux)on emmc not fell down .and then you feel emmc fix on board wait for board for cold. I hope you are seccess replacing emmc sorry for weak english Last edited by drjaved_akhter; 08-17-2015 at 16:55. |
The Following 10 Users Say Thank You to drjaved_akhter For This Useful Post: |
08-17-2015, 17:52 | #2 (permalink) | |
Freak Poster Join Date: Aug 2010 Location: pakistan
Member: 1383093 Status: Offline Thanks Meter: 52 | Quote:
how to clean.i mean use thinner or patrol... | |
The Following User Says Thank You to ahmc For This Useful Post: |
08-20-2015, 18:00 | #4 (permalink) |
Junior Member Join Date: Mar 2013
Member: 1899111 Status: Offline Thanks Meter: 4 | Hi ! wich temperature do you use to remove the emmc? We were having several troubles with the baseband, but we were doing it in one minute , surely with more heat . Will be waiting fr your kind reply! Regards! |
The Following User Says Thank You to outletcelular For This Useful Post: |
08-20-2015, 21:12 | #5 (permalink) | |
Member: 585807 Status: Offline Thanks Meter: 781 | Quote:
but i use matel sheiled black barry for cover basband ic cpu and pm ic.befor work i removed all glue pm small ic and basband ic and also cpu glue emmc side.you must removed also sim sokhet with matel . after replaced new emmc phone on no problem with imei 0049000000.if i use repair emmc with jtag then i flashed 4.3 verson and manual hard rest wipe and fectory..... | |
The Following 2 Users Say Thank You to drjaved_akhter For This Useful Post: |
08-21-2015, 14:14 | #8 (permalink) |
Freak Poster Join Date: Jul 2007 Location: in your heart Age: 37
Member: 557167 Status: Offline Sonork: 100.1626163 Thanks Meter: 12 | hi plz tell me witch is the best chemical to remove gelu that griper of emmc ic.. and many more ices gripe sorry for poor english. |
08-21-2015, 16:53 | #11 (permalink) |
Member: 585807 Status: Offline Thanks Meter: 781 | 1. after remove glue with hot air low heat and low air 2: cover with metal ..... 3; remove with small tussar 4 : clean with this wick...... please wait to be countine Last edited by drjaved_akhter; 08-21-2015 at 17:03. |
The Following User Says Thank You to drjaved_akhter For This Useful Post: |
08-21-2015, 18:01 | #13 (permalink) | |
efs: i use in 9300 this efs........ flash in odin 3.9 as ap.... https://www.4shared.com/file/82R5s3s...ir_efstar.html Last edited by drjaved_akhter; 08-21-2015 at 18:07. | |
08-21-2015, 18:13 | #15 (permalink) |
Member: 585807 Status: Offline Thanks Meter: 781 | i share to member now a days i am not removed emmc in 9300 7100 i use tp with easy jtag and repair emmc ... Last edited by drjaved_akhter; 08-21-2015 at 18:22. |
The Following 3 Users Say Thank You to drjaved_akhter For This Useful Post: |
