10-17-2013, 22:26 | #1 (permalink) |
Junior Member Join Date: Sep 2013
Member: 2036067 Status: Offline Thanks Meter: 2 | [HOW TO]Samsung Galaxy S4 Wireless Charging Mod [Touchstone Version]
----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- Ok Let's get started !!!!!!!!:highfive: (1) At first I'm going to introduce what's in this mod kit. ----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- As I know most of people will buy a pixi or pre back cover then peel the coil and sticker from it. But u should be very careful when peeling off the silver sticker, Any bend or damage will increase the risk of disturbing energy transfer. (1) Test before installing or soldering the coil to your phone. Once you put the coil and sticker above the touchstone you will hear some buzzing . 5.60v Non loaded voltage is normal.. (2) Find the Negative and Positive Terminal on your phone. MARK DOWN This is ATT SAMSUNG GALAXY S4. (This is just for reference cause some carrier has their own version ) ( Some version of S4 will not come with this connector,if you know circuit board you can solder wire directory to the component which controls USB CHARGING ) (3) Now we can work on the coil part. Desolder two square copper The red big square area is positive u set ur positive terminal in anywhere within this area. [I [MENTION=268591]wifi[/MENTION]xit_iphone me if you dont understand this step.[/I] (4) Trim the Nickle stick or copper tape On S4 I just cut two thick nickel stick and solder these two connectors (in the first pic) to the stick. Align the connector before you bonding the coil to your back cover. [MENTION=268591]wifi[/MENTION]xit_iphone me if you don't understand this step. (This is importan!!~~!!~~) Thanks for Reading. |
10-20-2013, 17:43 | #2 (permalink) |
Member: 2036067 Status: Offline Thanks Meter: 2 | You can get everything u need from here Palm Pixi and Pixi Plus Wireless Inductive Charging Touchstone for Galaxy S4 Mod | eBay |
