11-28-2004, 18:21 | #1 (permalink) |
Registered User Join Date: Sep 2003 Location: Palestine Age: 50
Member: 39208 Status: Offline Thanks Meter: 152 | I hear my voice in N620 ...!!! I have a samsung N620 the mic does not work on the other party ..., but i can hear my voice in the speacker ..., any suggestions ...? |
12-19-2004, 14:45 | #7 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 52
Member: 54993 Status: Offline Thanks Meter: 47 | Never try to reheat glued ICs ( CPU ). You can destroy the phone. Your audio path seems OK. you can put some sort of packing ( to press it on the board ) on CPU and audio ICs to solve this problem. Regards.. |
12-20-2004, 13:20 | #8 (permalink) | |
Freak Poster Join Date: Mar 2003 Age: 46
Member: 25392 Status: Offline Thanks Meter: 10 | lol Quote:
man wake up we are removing glue from almost 1 year for glued ic you can also use special hotting "plate" | |
12-20-2004, 20:38 | #9 (permalink) | |
No Life Poster Join Date: Oct 2003 Location: Lebanon / Nigeria Age: 52
Member: 42276 Status: Offline Thanks Meter: 47 | Quote:
thx | |
12-23-2004, 13:05 | #11 (permalink) |
Member: 25392 Status: Offline Thanks Meter: 10 | ok there are 2 ways at samsung models you need hot air and cutting tools... hot the glued ic at 320-350 celsius and force the ic with a tool it wiil desolder ...just test on a dead board.....the hard part is to clean the mainboard.... i use a very sharp tip at 430 celsius...and i remove the glue by presind the tip to glue ....... .....this is for samsung hard part is for nokia ...there i use a removing lichuid a atached here the pdf wich was atached to removing glue solution the way for using removing glue solution is not soo easy i use a small piece of coton ...and a small quantity of solution ...i put the cooton on ic wich has to be removed...i put the board in a sealed plastic bag...and i let the mainboard for 1-3 days after 2-3 days i use hot air for desoldering ic ....i clean remaing glue on the mainboard with a soldering iron at 420 degres |
12-23-2004, 19:04 | #13 (permalink) | |
Member: 25392 Status: Offline Thanks Meter: 10 | read again Quote:
soldering iron not hot air tested on many phones... but solution is working on 70% cases | |
12-25-2004, 15:30 | #15 (permalink) | |
Member: 25392 Status: Offline Thanks Meter: 10 | well i.m not the first Quote:
im not the first one wichis doing that i will make photo to a mainbord of 6310i with uem replacement(monday iwil make photos) i will show the steps..... anyway...i dont need to be belived....i realy doing this..and few frend of mine are doing same thing...there are few posts on this forum also about removing glue | |
plz help for 1200 mic not working i hear my own voice in speaker | bruightmobile | Nokia Hardware & Hardware Repair | 3 | 02-13-2010 10:00 |
My MTK makes my voice sound strange to callers | nadimrafik | Chinese Models & Cloned Phones | 7 | 02-07-2010 00:07 |
Which Software Used To Hear Mp3 Songs In 1600? | zonetrichur | Nokia Multimedia | 0 | 12-28-2006 06:00 |
help me abut my mobile Samsung N620 | gsm_spzone | VLSI, Conexant, Skyworks and Old Models | 2 | 06-15-2005 18:42 |
3510: I hear network searching in Buzzer | Chris02 | Nokia Hardware & Hardware Repair | 13 | 07-05-2004 19:55 |
