07-12-2007, 04:34 | #1 (permalink) |
Junior Member Join Date: Jul 2007
Member: 544627 Status: Offline Thanks Meter: 0 | i need help in samsung D900i i have problem in my samsung D900i 1) i can not install any java prog in the phone. 2) i have try this code *#528283783# and i have reset the TFS so imy jave games r displayed in smaller size and i don't know what to do. can u help me plz thanks alot |
11-26-2007, 17:26 | #2 (permalink) |
Junior Member Join Date: Sep 2007
Member: 591067 Status: Offline Thanks Meter: 0 | im having the same problem i think. I cant install java games after flashing the phone with new software. I think the java games from before are taking up the space for java games... is there a way to delete all the java files that are not showing up in the java menu? |
12-23-2007, 17:26 | #3 (permalink) | |
Junior Member Join Date: Dec 2007
Member: 659746 Status: Offline Thanks Meter: 0 | Quote:
Softick PPP 2.21 (This is ment to be for different models so it will have some errors but they dont affect what your doing.) Both can be found here: http://www.d500world****/THEN 1. Go to "Applications\Java world\Options" in the options menu go to the Network settings and fill in this: APN: internet Username: <leave blank> Password: <leave blank> Proxy: OFF Save settings. 2. Install Softick PPP 2.21 but don't run it yet.(You will get an error about a usb drive missing. Just cancel it.) 3. Connect your phone with the USB cable to computer and run Samsung PC Studio to check if it is connected . If no find out why.( if your setting in phone setting/Usb settings = mass storage it will not work. So change this to modem and change back later.) If yes continue Close Samsung PC Studio. 4. Enter *#52828378# and select OTA Type Setting menu, switch from GPRS OTA to Serial OTA. 5. Then start Softick (not active yet) and go to "Bluetooth/Serial" tab. if "ss_mdm0" appears . Check it. (might get a error here to just cancel it.) Then enable Softick ppp. 6. Start samsung java uploader and load JAD file/files in uploader. (If you get an error about not enough rights ect.. turn off your virus software and check that it hasn't added it to a list of file to deniy access to.) 7. Enter Serial Java menu #*5737425# and choose "PPP UP" and then "USB", then Serial download. Watch the download and launch the software. If loaded more than one jad file exit game and goto step 7. Switch back from Serial OTA to GPRS OTA to get WAP working. ( if you changed your usb setting from mass storage to modem change this back to. ) Trouble Shooting. If your phone just turns off and restarts without loading anything. it will probly be a connection error. try the following. start pc studio and check the connection. If not connected shutdown Softick completely. Unplug your phone from the usb cable. Change step 4. back to Gprs ota. Connect phone back to usb cable. check the connection in pc studio. You may no automaticly find it and you will have to go file/connection , connect. once connected close all samsung pc studio software and go back to step 4 and continue. Softick and pc studio dont like runnig together. wait for reply | |
Need help in samsung s3500 | invisible990200 | Trident/AGERE Platform | 9 | 03-24-2010 13:37 |
need help in changing imei of Samsung i8910 Omnia HD | atspilot | Samsung Flashers, Software, Firmware. | 6 | 02-04-2010 19:48 |
need help in samsung 399& samsung champ269 | skagrll | Various CDMA/TDMA Cell Phones | 0 | 04-01-2009 07:42 |
Help In Samsung P910 In DB MODE | MasK GsM | UST Pro II | 6 | 08-21-2006 19:05 |
Need Help in Unlocking SAMSUNG t809 | nesbpserv | UFS2 + UFS3-Tornadoflasher | 1 | 05-07-2006 14:52 |
