08-29-2015, 21:22 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: karachi
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | i317 very weak signal and emergency calls only in open area show signal but not stable someone already removed external antenna and make jumper so i put jumper from antenna pin in charging port to external antenna on pcb but same any good suggestion will be appreciated |
08-30-2015, 06:16 | #2 (permalink) | |
No Life Poster Join Date: Mar 2003 Location: INDIA Age: 57
Member: 25662 Status: Offline Thanks Meter: 190 | Quote:
08-31-2015, 22:07 | #3 (permalink) |
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | i change charging port and antenna wire but still same actually external antenna already removed from pcb and one print of external antenna print which goes to pa damaged anyone can share here complete signal ways ? |
09-03-2015, 06:00 | #11 (permalink) | |
If get weak network than change FEM ic in 2nd step. before same post forgot to post img. | |
09-04-2015, 02:24 | #12 (permalink) | |
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | Quote:
than it show signal in room but not full, when i soldered to pin on charging flex than no signal or if signal than only emergency calls | |
09-04-2015, 06:26 | #13 (permalink) |
Member: 25662 Status: Offline Thanks Meter: 190 | change charging flex or trace line of signal path. Don't connect 10cm. wire to charging flex it will not give complete signal. use anttena cable in proper way to get full signal. My doubt is FEM ic. once change it. |
