Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 08-29-2015, 21:22   #1 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
i317 very weak signal and emergency calls only
i317 very weak signal and only emergency calls
in open area show signal but not stable
someone already removed external antenna and make jumper
so i put jumper from antenna pin in charging port to external antenna on pcb but same
any good suggestion will be appreciated
Old 08-30-2015, 06:16   #2 (permalink)
Member: 25662
Thanks Meter: 190
Check in another charging flex and antenna cable.
Old 08-31-2015, 22:07   #3 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
i change charging port and antenna wire but still same
actually external antenna already removed from pcb and one print of external antenna print which goes to pa damaged
anyone can share here complete signal ways ?
Old 09-01-2015, 05:39   #4 (permalink)
Member: 25662
Thanks Meter: 190
upload photo both size
Old 09-01-2015, 23:10   #5 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
chk the pictures
charging + antenna flex
backside of pcb
Old 09-01-2015, 23:12   #6 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
front side of pcb
braken antenna point
Old 09-02-2015, 06:09   #7 (permalink)
Member: 25662
Thanks Meter: 190
front side of pcb
dear pls.. 1st clean pcb with pcb cleaner and than take photo.
I had seen it but due dark flux can't see proper track.
Old 09-02-2015, 12:10   #8 (permalink)
Member: 25662
Thanks Meter: 190
1st jumpper 10cm. in air. If you get full network than connect to cable socket.
If get weak network than change FEM ic in 2nd step.
Old 09-02-2015, 14:43   #9 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
fem is pa ic .......?
Old 09-03-2015, 05:58   #10 (permalink)
Member: 25662
Thanks Meter: 190
no fem ic is FRONT END MIXER module its separte rx tx of all verious band.
Old 09-03-2015, 06:00   #11 (permalink)
Member: 25662
Thanks Meter: 190
before same post forgot to post img.
Old 09-04-2015, 02:24   #12 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
i put 10cm wire and sold one side and other leave in the air
than it show signal in room but not full, when i soldered to pin on charging flex than no signal or if signal than only emergency calls
Old 09-04-2015, 06:26   #13 (permalink)
Member: 25662
Thanks Meter: 190
change charging flex or trace line of signal path. Don't connect 10cm. wire to charging flex it will not give complete signal. use anttena cable in proper way to get full signal. My doubt is FEM ic. once change it.
Old 09-05-2015, 00:23   #14 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
sir u have schematics and service manual of this model ?
Old 09-05-2015, 02:27   #15 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
here are clear and zoomed pictures
pcb
flex
make jumper like this but not get good signal in open area signal fine but in room no signal or get 2-3 signal bars but not make call
missing parts
i chk on other pcb it is like a small coil
Page generated in 0.19213 seconds with 9 queries
