04-09-2013, 21:28 | #2 (permalink) | |
Insane Poster Join Date: May 2008 Location: Israel Age: 40
Member: 775828 Status: Offline Thanks Meter: 44 | Quote:
or you can try solution to swap emms to microsd card/ you need to remove old emmc, after take 16g or 32g microsd class10 format and burn 2 partition in "GPARTED"-program/1-(2g-rfs) and second partition on fat 32. Put this card to phone -reflash 3 files firmware with pit. After flash Ceanogen rom -7.2 , and after that you need to repair setings on file system because the phone in default dont see internal SD. If you really want to do this solution( TESTED by ME and working perfect!!) I will write you step two - what you need to change in setings foraviable sdcard | |
The Following User Says Thank You to genych For This Useful Post: |
05-02-2013, 08:05 | #5 (permalink) | |
Freak Poster Join Date: Feb 2007 Location: In Your Heart
Member: 451538 Status: Offline Thanks Meter: 98 | Quote:
thanks | |
05-04-2013, 00:42 | #6 (permalink) |
Member: 775828 Status: Offline Thanks Meter: 44 | 1. remove old emmc 2.Take 16gb class 10 , put to PC , 3.Boot Gparted iso 4.create 2 partition /first-resrfs=2000mb/second fat32=rest of it 5.Put this sd card to phone and flash 3 files firmawe with pit file.Do factory wipe 6.Install Root to phone 7.Install this zip : https://hotfile.com/dl/211258401/ba111e3/ES.zip.html 8.Open ES_fileexplorer on phone,go to settings and check all "V" in root setings,Then go to main page of this program and tab on "UP"(folder icon). 9.Go to:system/ets and open "Voldstub" file (wit note) and now be acurate 10, change parameters to # internal sdcard: dev_mount sdcard1 /mnt/sdcard/external_sd 1 /devices/platform/mmci-omap-hs.1/mmc_host/mmc0 # externel sdcard dev_mount sdcard /mnt/sdcard 1 /devices/platform/mmci-omap-hs.0/mmc_host/mmc1 11.tab on back and back, save changes and reboot your phone. 12.Engoy and dont forget , this solution working for all originall firmwares. P.S for custum firmware another setings of voldstub file |
09-25-2013, 13:46 | #11 (permalink) | |
No Life Poster Join Date: Mar 2013 Location: Nepal Age: 41
Member: 1906979 Status: Offline Sonork: 100.1681049 Thanks Meter: 162 | Quote:
