Unlock Server
Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Samsung > Samsung Hardware Repair Area
Samsung Hardware Repair Area Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 03-21-2012, 19:31   #1 (permalink)
Member: 76643
Sonork: 100.1606758
i9000 only power up with charger
hi there guys,
i have one i9000 Galaxy S with strange problem. phone works ok but the problem is that if phone is turned off i cannot power up. the only way that i can power it up is to insert a charger or data cable and then i can push the power button and phone is powering. after that i can remove the charger, and phone is working normally. when the charger is not pluged into phone charger if i try to power it up it only shows the please wait symbol and after that the empty battery symbol but phone is not powering even if the battery is fully charged !!! any solution?? please give me a solution .
Thanks!!!
The Following User Says Thank You to padi For This Useful Post:
Old 03-22-2012, 06:38   #2 (permalink)
Member: 76643
Sonork: 100.1606758
nobody ??? no ideea??
Old 03-22-2012, 06:50   #3 (permalink)
rumenshom's Avatar
Member: 899774
Sonork: 100.1586303
did u check or change battery connector?
Old 03-22-2012, 08:38   #4 (permalink)
Member: 76643
Sonork: 100.1606758
again
i've checked everything, board - no oxidation, battery conectors are ok, charging socket is ok - no oxidation , no tear, nothing seems to be wrong. phone is charging normaly and once is started up it shows the real battery level. i've even clean the board with ultrasonic cleaner, reflash with original software version just to be sure is not software related or oxidation (even if is not ). i think some track is broken or a capacitor or termistor is getting me crazy. one more thing, the phone is having sometimes problems connecting to pc, it's not recognized, pc shows unknown device or somethig like that, but only sometimes (especialy when the case is closed firmly and screws well tighten.
any idea??
Old 03-22-2012, 09:15   #5 (permalink)
dubai@mobile's Avatar
Member: 1711454
Sonork: 100.1605681
brother check charging jack....................
Old 03-22-2012, 09:18   #6 (permalink)
Member: 1736451
the only solution... change charging connector..
100% solution
Old 03-22-2012, 09:51   #7 (permalink)
azharjamal's Avatar
Member: 804115
Sonork: 100.1625940
s change the charging conector that for only one solution
Old 03-22-2012, 12:29   #8 (permalink)
Member: 76643
Sonork: 100.1606758
i've allready told you guys that charging connector is ok , i even resolder it and same thing. i change the usb driver ic and for few minutes phone seemed to work ok. but after a while same problem apear. i think is a track broken in the pcb and while pcb was heating when i change the ic, the track maked a connection but when pcb got cold problem reappeared.
any other solution??
Old 03-22-2012, 13:04   #9 (permalink)
Member: 962560
Sonork: kenji1258
try to check power switch...maybe its crowded......
Old 03-22-2012, 15:27   #10 (permalink)
Member: 237474
power switch
yes check power switch
Old 03-22-2012, 19:33   #11 (permalink)
Member: 76643
Sonork: 100.1606758
hello
i finaly finish the work with this crazy i9000. so i've changed the vbus charge regulator ic , rework the Maxim Max 8987 DC power management ic, changed the charging connector and now the phone is working ok. i've even reflash it and this time i have no problem with connection. all is working well, phone powers now ok and usb connection is safe and continuous. charging is also ok now.
thanks guys!!!!!
and say thanks if helped someone of you!!!!! ))
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 04-10-2013 02:07
Sim card sleep mode problem with 6130 ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 05-22-2012 11:13
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-25-2009 16:29
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 07-16-1999 00:44
Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 06-09-1999 17:04
Page generated in 0.44657 seconds with 10 queries
