04-28-2013, 10:15 | #1 (permalink) |
Crazy Poster Join Date: Mar 2012
Member: 1731395 Status: Offline Thanks Meter: 34 | i9001 always shows charging Thanks in advance |
05-23-2013, 21:41 | #3 (permalink) |
Junior Member Join Date: Sep 2007
Member: 592727 Status: Offline Thanks Meter: 0 | i9001 charge problem i need ways track microusb,because socket usb is was torn from the motherboard, and do not know which connections to be made with leftover tracks,y need to help. thanks in advance |
05-23-2013, 22:49 | #4 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: Al-Ahsa Saudi Arabia Age: 35
Member: 253510 Status: Offline Sonork: 100.1672352 Thanks Meter: 3,534 | Quote:
br | |
The Following User Says Thank You to .::M Irfan::. For This Useful Post: |
05-24-2013, 04:37 | #5 (permalink) | |
No Life Poster Join Date: May 2011 Location: gsm-forum
Member: 1573913 Status: Offline Sonork: hardware illustration Thanks Meter: 7,619 | Quote:
samsung gt-I9001 Galaxy S Plus charging ways pin1 = VBUS pin on C558 pin 2 = usb_DM at R527 pin 3 = usb_DP at R526 pin 4 = usb_ID at R525 pin 5 = ground pin 6 = Vbat in TA502 and ZD500 caption: pin 1 position in the scheme is not clear sorry if its composition inverted see the picture below dont forget press thank | |
05-24-2013, 04:43 | #6 (permalink) | |
05-28-2013, 20:07 | #9 (permalink) | |
Member: 592727 Status: Offline Thanks Meter: 0 | i900i ways charge microusb Quote: 1 - Vcc + 5v charge 2 - data bus usb_dm 3 - data bus_ dp 4 - usb id 5 - ground - 6 - V batt gnd - 7 - ground - thanks very much for picture motherboard i9001 version 0,5. routes that are in the picture you posted it does not correspond exactly to the wiring diagram from service manual Please check the new configuration corresponded to pin microUSB jack from the motherboard version 0.5 - I9001 that you have? I want a picture of the motherboard in the microUSB socket without checks if corresponding paths drawn according to plan. | |
