10-21-2011, 12:33 | #1 (permalink) |
No Life Poster Join Date: Oct 2010 Location: Lebanon Age: 36
Member: 1424719 Status: Offline Sonork: 100.1619833 Thanks Meter: 2,563 | Samsung D870 Not entering in slave mode! while flashing it , the master flashes are done without error! But when it comes to the slave part : MCU File: D780XFHG1_Master.cla CRC32: 5EC0E94F TFS File: D780XFHG1_Master.tfs CRC32: 53247F87 CFG File: D780XFHG1_Master.cfg 208942 byte(s) MCU File: D780XFHG1_Slave.cla CRC32: CC0202B1 TFS File: D780XFHG1_Slave.tfs CRC32: B4293435 CFG File: D780XFHG1_Slave.cfg 465 byte(s) MCU Id: 3541, PNX5230/31 Preloader Ok, 921600 Baud Flashloader Ok FLASH Id: 00EC2206000100000034, Samsung KAP29WG00M [NAND 1G] NAND Format Complete, Time: 00:09 File CRC: 0x5EC0E94F MCU Write Done, 26680332 byte(s), Time: 07:04 File CRC: 0x53247F87 TFS Initialised: 1 TFS Version: TFS4.0_CORONA_01 Directories: 164 Max_Files : 2712 Files_Count: 2712/2712 TFS Unmounted TFS Write Done, 56566241 byte(s), Time: 19:23 2nd Boot Failed: Bad 2nd Boot Response: Ive posted it in the software section and it comes out that it is hardware problem!! Any idea how to fix it?? 10x in advance |
12-03-2011, 15:09 | #4 (permalink) |
No Life Poster Join Date: May 2007 Location: INdIa
Member: 517316 Status: Offline Thanks Meter: 185 | Bro did you solved your problem.........? I'm also facing same problem with D780.........not able to flash the slave part.... if anyone knows the solution please post here..........! |
04-16-2012, 22:51 | #7 (permalink) |
Freak Poster Join Date: Dec 2004 Location: albania Age: 45
Member: 95440 Status: Offline Thanks Meter: 25 | is not software problem is hardware .. connection between main cpu end second cpu is lost.. you need to rebuild this connection 1 reheat power ic rf ic 2 reball cpu |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
Lock 2 in nokia 51xx/61xx | Pablo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-31-1999 04:35 |
