Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 03-16-2013, 12:12   #1 (permalink)
Member: 1670865
Thanks Meter: 2
I9100 Charging paused. Battery temperature too high or to low.
Hi all.
I have an Galaxy S2 I9100 after water contain.
Charging doesn't work. It shows a message "Charging paused. Battery temperature too high or to low." and it won't charge anymore. Definitely hardware issue. I have already replaced charging connector and rehaeted mainboard - didn't help at all
Anybody could help me pls?
With regards
pioter_z
Old 03-16-2013, 13:09   #2 (permalink)
GSMsurgeon's Avatar
Member: 6524
Thanks Meter: 239
100% harware fault
I have done lots...just replace charging connector with flex...ic damaged in this flex...
Old 03-18-2013, 16:11   #3 (permalink)
Member: 1670865
Thanks Meter: 2
Nope mate, I already replaced it and I replaced battery as well.
Got info from a friend it could be DCDC Converter. Anybody could confirm?
Regards
pioter_z
Old 03-18-2013, 19:29   #4 (permalink)
Member: 529040
Thanks Meter: 13
Change charing ic or reball and try out ...
Old 03-18-2013, 23:48   #5 (permalink)
Member: 1843401
Thanks Meter: 11
Originally Posted by krish neupane View Post
If not done first solution then try this final solution.
Cange This IC (MAX8627ETD) Resolve The High Temp in the Display (!) and normal recharge your battery ....
Old 04-08-2013, 13:30   #6 (permalink)
Member: 1670865
Thanks Meter: 2
IC Changed but still not working I just gave up, but if someone would find out solution please write here. For others might be helpful.
Regards.
Pioter_z
Old 04-08-2013, 13:54   #7 (permalink)
Member: 21937
Thanks Meter: 278
Regards.
Pioter_z
just posted about same problem.
if anyone can help
thanks
The Following User Says Thank You to TRABEL For This Useful Post:
Old 04-20-2013, 09:55   #8 (permalink)
Member: 501198
i have just cleaned the pcb and problem has been solved
Old 04-20-2013, 16:10   #9 (permalink)
Member: 1843401
Thanks Meter: 11
I Found a new solution to the problem of high temperature.
After you change the component U504 ...
and you still have error of High Temperature ...
and results from the display as Connected in USB MTP detected as ...
Replace the component U503 ....
Everything works 100%
Old 08-14-2013, 16:55   #10 (permalink)
Member: 2001730
pioter_z I have the same phone and have the same problem with it I have taken it in to a repair shop to see about it and they had told me that you will have to replace the mother board because that is what had happened is it screwed up the motherboard
Old 08-15-2013, 15:55   #11 (permalink)
Member: 1972455
Hi all.
With regards
pioter_z
Hi! It means the damage has already been done, and i am sure youor charging connector is water damaged. If you have already reheated it and it is still the same than you should go with replacing the charging connector, as that's the only thing that you can do in order to overcome this problem.
Old 08-15-2013, 19:05   #12 (permalink)
Member: 1869842
Sonork: 100.1625473
Thanks Meter: 152
Hi all.
With regards
pioter_z
Try this in the schematic
The Following 2 Users Say Thank You to habibboxes For This Useful Post:
Old 09-19-2013, 17:10   #13 (permalink)
UU2
Member: 21987
Thanks Meter: 27
Hello guys!
The Q500 is where,this type of motherboard?
Because it is a qvarc .....
Old 09-21-2013, 03:36   #14 (permalink)
Member: 2030388
hi in which site can i buy this IC
hi in which site can i buy this IC i have searched in ebay but coudent find it plz help
Old 09-21-2013, 11:58   #15 (permalink)
Member: 730798
Thanks Meter: 43
IC-Charger 100%, done many like these problems.
Page generated in 0.70176 seconds with 8 queries
