09-22-2013, 08:06 | #16 (permalink) |
No Life Poster Join Date: Feb 2003
Member: 21987 Status: Offline Thanks Meter: 27 | http://forum.gsmhosting.com/vbb/f258...-warm-1714227/ |
12-23-2013, 14:38 | #17 (permalink) |
Major Poster Join Date: Nov 2012
Member: 1843401 Status: Offline Thanks Meter: 12 | For the same error caused by water damage - " Load pause - Battery too Hot " - Checking the temperature manually integrated into the motherboard of you may note excessive heating of the large integrated " MOD201 " - IC Form W-LAN and Bluetooth - samsunggt-i9100S2charging-notsave_zps9781b1c0.jpg Photo by d-Artigo | Photobucket In this case Checking if all other components that are functional .... You can 'desolder this integrated and do the test without this integrated charging the phone .... Replace if after the tests do not have more error in charging ..... Tested and running at 100% |
11-07-2014, 14:38 | #18 (permalink) |
Freak Poster Join Date: Jun 2013
Member: 1965565 Status: Offline Sonork: mohd_nadeem231 Thanks Meter: 16 | Battery temperture high Same problem facing n7000 and i9300 change charing ic but same problwm no solution for than problem if have the solution than plz share |
12-30-2014, 23:01 | #20 (permalink) |
Freak Poster Join Date: Mar 2007
Member: 464270 Status: Offline Thanks Meter: 56 | i found ths solution but havent tested!! http://www.youtube.com/watch?v=u1f2CI2_g6I try it and tell us |
01-03-2015, 01:17 | #21 (permalink) |
Freak Poster Join Date: Sep 2007 Location: cambodia
Member: 578236 Status: Offline Thanks Meter: 31 | This problem should be chase as the following 1 change charge flex 2 clean the pcb 3 change charge IC if not solved 3 change all condensor or resister which connected with the charge schematic 4 if not solved , the last one is change PMIC mine one which i have met this few day is CHARGE ic បើប្អូនៗបានជួប សូមសាកល្បងតាមហ្នឹងមើលក្រែងមានប្រយោជន៍ |
06-09-2015, 07:20 | #22 (permalink) |
Junior Member Join Date: Mar 2011 Location: kodungallur Age: 39
Member: 1544929 Status: Offline Sonork: shafeermadavana Thanks Meter: 0 | charging paused temperature too high i hve samsung mobile sm-g313 ,its hve problem battery charging paused temperature too high,i changed usb port,change battery but prblm cant solved plzz help me |
07-28-2018, 13:55 | #25 (permalink) |
Crazy Poster Join Date: Sep 2004 Location: uk sunny brighton :) Age: 59
Member: 80338 Status: Offline Thanks Meter: 2 | Just had a Samsung i9100 which would not charge as temperature of battery too low! After changing the obvious I found a component was dislodged on the pcb! I cannot tell whether its a resistor or capacitor. However check out the attached picture for the location of the component. Component is circled with red. Resoldered and cured the problem I had almost given up and was looking at the defective pcb and noticed it was dislodged. I can only guess from the phone being dropped! |
