08-07-2013, 16:59 | #1 (permalink) |
No Life Poster Join Date: Feb 2003
Member: 21987 Status: Offline Thanks Meter: 27 | i9100 Galaxy S2 no DISPLAY SOLUTION! If anyone encounters this error:no display and U501 Max8997 IC warms. To replace the IC the problem is solved! Tested in two pieces! Samsung i9100 keine Anzeige Service: Max8997 IC. | eBay |
08-23-2013, 08:22 | #2 (permalink) |
Freak Poster Join Date: Jun 2007
Member: 530783 Status: Offline Thanks Meter: 12 | I have this same problem sometimes starts but is locked. I discovered that a lot Max8997 heats and crashes, screen off etc ... I'm thinking about changing it but my fear is if you can have more bad components that also heated .. I think it's by Max8997 this is heated to 45c-50c º º but in a while the temperature is lowered but the phone and screen already off .. Only I have to change the Max8997? |
08-23-2013, 12:52 | #3 (permalink) |
Member: 21987 Status: Offline Thanks Meter: 27 | For "professionals" only recommend a replacement! For those who have not done it before does not really stand her ..... http://www.ebay.de/itm/171111703900?...#ht_143wt_1328 |
08-23-2013, 19:03 | #5 (permalink) |
Member: 530783 Status: Offline Thanks Meter: 12 | I will be complicated in order to return the phone now locks me more .. make noise and be heard but the screen freezes this is what I have to do? Be removed without probelmas the ic but my problem is when I move the welding component and I can not .. I only practiced with it at the moment old phone but not to remove solder. When I remove the IC I have to remove all the tin on both sides? I have to put one flux? or tin in pasta? I see that in the youtube video that uses a white paste is flux paste? https://www.youtube.com/watch?v=ce0bCRnY_A0 |
09-14-2013, 08:11 | #7 (permalink) |
Member: 21987 Status: Offline Thanks Meter: 27 | If the battery is positive connector shorted to ground and a capacitor not shorted forum.gsmhosting.com/vbb/f258/samsung-galaxy-s2-i9100-short-circuit-solution-1537757......is a Max8997 IC shorted!!! Tested! |
09-20-2013, 23:20 | #8 (permalink) |
Member: 530783 Status: Offline Thanks Meter: 12 | help with my i9100... I need desperate help buy the max ic for change and apparently all fine until I put the chip is not good and I miss a pad first one and then another and was missing 3 pads in the corners and do not know how I can reset .. I'm buying a microscope believe it is essential right? which I advise? on the other hand I've realized that I need a resistor smd Ariba as I can not find that resistance is and I did not realize I do not know if I missed or lacked longer before I realized too late .. please help ..! |
09-21-2013, 12:23 | #9 (permalink) |
No Life Poster Join Date: May 2011 Location: gsm-forum
Member: 1573913 Status: Offline Sonork: hardware illustration Thanks Meter: 7,629 | Quote: 1. point or pad is at the top right corner 2. missing components are SMD Inductor with 39 nH and a tolerance of 5% for FM RADIO ANT |
09-21-2013, 12:48 | #10 (permalink) |
Member: 530783 Status: Offline Thanks Meter: 12 | this product?0805 39nH SMD inductor 50PCS 0805 39nH SMD inductor | eBay regarding my problem of the pads not well understood ... my problem is that I have broken the pads sauteed in red just the corners. Not if you understand me ..? Raised the track .. I'm gonna buy a microscope to help see connections MAX8997 |
