09-10-2013, 09:17 | #1 (permalink) |
Junior Member Join Date: Sep 2013
Member: 2021412 Status: Offline Thanks Meter: 0 | i9100 not charging, battery with thermometer bought the phone at the auction. according to the seller burned to charge. board looks clean, free of oxides. between the terminals of the battery connector was a short circuit. first thought on u501, sealed-off it was not her. found fault in S565 about u503. Sealed-off capacitor and soldered u501 and turn the phone on. but I'm not happy for a long time. when the battery began to appear with a thermometer. Sealed-off u503, u504, the thermometer is not lost. measured the consumption on the bare board without including - 100mA. started digging and eventually made Reball u501, consumption has disappeared. Now the phone without u503, u504. The phone is switched off batteries, power supply unit for some reason does not start, but when you press the power button appears in the consumption of 100mA. after disconnecting and connecting again, the consumption is already without pressing the power button. insert the battery and the phone begins to turn on itself. decided to charge the battery separately. the terminal voltage has risen to 3.9V, inserted into the phone and the phone by pressing the power button is already showing a battery with a thermometer and is not turn on. i dont know what to do now Sorry for my english |
09-19-2013, 15:24 | #2 (permalink) |
No Life Poster Join Date: Feb 2003
Member: 21987 Status: Offline Thanks Meter: 27 | http://forum.gsmhosting.com/vbb/f258...-warm-1714227/ Th401 (R481,R482) defekt...water demage. The question, but just to be replaced by the TH400, R402, R403 parts?? The answer is YES!! The unit charging perfectly! (Temp.:35C) |
