02-08-2013, 23:49 | #1 (permalink) |
Freak Poster Join Date: Nov 2008
Member: 895045 Status: Offline Thanks Meter: 14 | i9100 wifi not working but bluetooth ok I received this i9100 because charging andwifi problem.Solved the charging issue but wifi cannot ON / grayed.Tried software downgrade and upgrade still same but bluetooth working good.Any solution?Pls help powerstars!Thank you |
03-27-2013, 13:51 | #4 (permalink) |
Junior Member Join Date: Mar 2003 Location: ROMANIA Age: 47
Member: 24594 Status: Offline Thanks Meter: 0 | check MOD201 and r203,r204,r206,r207 it is possible that the liquid from the back-up batter to have leaked out and corrpde them thus making the circuit unoperable! |
04-11-2013, 17:51 | #5 (permalink) |
Junior Member Join Date: Apr 2013
Member: 1915094 Status: Offline Thanks Meter: 0 | Same problem here. I am checking this: 8-3-7. BT/WIFI for Samsung GT-i9100 service manual |
02-09-2015, 05:56 | #7 (permalink) | |
No Life Poster Join Date: Jul 2013 Location: Nepal,kathmandu
Member: 1988630 Status: Offline Sonork: 100.1684003 Thanks Meter: 312 | Solution to Repair WiFi on i9100 Quote:
thanks | |
07-13-2017, 00:24 | #10 (permalink) | |
No Life Poster Join Date: Jan 2013 Location: lebanon
Member: 1869842 Status: Offline Sonork: 100.1625473 Thanks Meter: 186 | Quote:
2-check r203/r204/r205/r206/r207=2.8v *if yes check r203/r204/r205/r206/r207 (crack damge etc...) *if not make a jump wire for c542=2.8v pinout to r203/r204/r205/r206/r207 that is attachecd to each other same side that will appears using multimeter buzzer sound when you get noise 3-resolder or replace mod201(wifi ic) | |
