01-15-2015, 02:01 | #3 (permalink) |
Freak Poster Join Date: May 2006
Member: 272137 Status: Offline Thanks Meter: 75 | Next to the antenna is baseband chip ,it's been burn take out reball and put it back if you can ,after remove baseband chip phone will be still works same as now, no Imei and baseband ..if you successfully reball it and put it back Imei will come back ..gudluk |
01-15-2015, 02:05 | #4 (permalink) |
No Life Poster Join Date: Jul 2005 Location: karachi
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | i flash the phone with this file (I9100GXXLPY_I9100GXXLPV_I9100GDBTLP3_HOME.tar.md5 ) using odin but still same when i dial this code *#1234# lcd show PDA : I9100GXXLPY PHONE : UNKNOWN CC: I9100GDBTLP3 |
01-15-2015, 02:41 | #5 (permalink) |
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | <ID:0/022> Added!! <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> I9100GXXLPY_I9100GXXLPV_I9100GDBTLP3_HOME.tar.md5 is valid. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/022> Odin v.3 engine (ID:22).. <ID:0/022> File analysis.. <ID:0/022> SetupConnection.. <ID:0/022> Initialzation.. <ID:0/022> Get PIT for mapping.. <ID:0/022> Firmware update start.. <ID:0/022> cache.img <ID:0/022> NAND Write Start!! <ID:0/022> factoryfs.img <ID:0/022> hidden.img <ID:0/022> MLO <ID:0/022> modem.bin <ID:0/022> param.lfs <ID:0/022> Sbl.bin <ID:0/022> zImage <ID:0/022> RQT_CLOSE !! <ID:0/022> RES OK !! <ID:0/022> Removed!! <ID:0/022> Remain Port .... 0 <OSM> All threads completed. (succeed 1 / failed 0) <ID:0/011> Added!! <ID:0/011> Removed! |
