04-06-2016, 13:45 | #1 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Now on earth Age: 48
Member: 75290 Status: Offline Thanks Meter: 57 | I9195 touchscreen IC ? I've I9195I and touchcreen doesn't work. I checked on another display and work noramly. SO problem is with hardware (PCB). Somebody know where is in I9195 touchscreen IC ? BR ERSA Seb |
04-18-2016, 13:36 | #4 (permalink) | |
Junior Member Join Date: Jan 2016
Member: 2523862 Status: Offline Thanks Meter: 0 | Quote:
you got a result? cause i got the same problem with 2 s4 mini I9195I and on both no touch. lcd works but no touch | |
09-04-2017, 13:25 | #7 (permalink) |
Junior Member Join Date: Jan 2007
Member: 428283 Status: Offline Thanks Meter: 4 | i9195i help fake charge hello i need a helper i have an i9195i at a fake charge stops at 16 17% the camera flash only works if plugged in to the power i replaced the charging connector but i did not fix someone to a solution thanks. |
