06-30-2014, 00:16 | #3 (permalink) |
Junior Member Join Date: Dec 2013
Member: 2083929 Status: Offline Thanks Meter: 0 | - Double check your battery for volts with multimeter - carefully inspect usb replacement with lighted magnifier - check for volts to usb pins on circuit board - check for volts at the battery connector |
07-03-2014, 07:23 | #4 (permalink) |
Freak Poster Join Date: Jun 2013
Member: 1952487 Status: Offline Thanks Meter: 43 | Hi, I have had the issue before.. Probably the flux shorted or something because after cleaning well the board with IPA or 99% alcohol I let the board dry for 10 minutes and than it worked... In case it doesn't help remove the charging socket you soldered and test if device works. |
