Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 11-17-2014, 21:42   #1 (permalink)
Member: 1616463
Sonork: 100.1660594
Thanks Meter: 247
i9300 microphone & earphone not working during a call
Hello everyone,
I recieved a samsung i9300 with android 4.1.2 which works properly until it recieves a call then the microphone, earphone and its speaker stops working but after the call everything is allright again. What i did was first wipe the device then checking the microphone way and changed every resistors and audio ic from a working phone. But my problem is not solved! Do anyone has an idea?
Thanks in advance
Old 11-19-2014, 18:58   #2 (permalink)
Member: 1616463
Sonork: 100.1660594
Thanks Meter: 247
no solution?????........
Old 11-21-2014, 19:55   #3 (permalink)
Member: 2237030
Thanks Meter: 9
Audio processor fault (u604)
Old 11-23-2014, 09:51   #4 (permalink)
monishkylm's Avatar
Member: 1434825
Thanks Meter: 6
Check if ur phone have n/w while in call.
Am workin @ samsung service.
Hav got the same issue , no audio while call is connected . I hav observed that the n/w goes down while call is connected.
Changed the n/w oscillator nd problem was solved. Try it.
Best of luck buddy...
Old 11-23-2014, 16:21   #5 (permalink)
Member: 2237030
Thanks Meter: 9
Belive me it is a tipical audio processor fault
Old 11-23-2014, 20:38   #6 (permalink)
Member: 1616463
Sonork: 100.1660594
Thanks Meter: 247
as i told in my first post i have already changed everything (audio processor, resitors...) on the way from a working phone. nothing was solved.
Old 11-23-2014, 20:41   #7 (permalink)
Member: 1616463
Sonork: 100.1660594
Thanks Meter: 247
i will try your answer and report if it worked.
Old 12-04-2014, 10:00   #8 (permalink)
Member: 1514905
samsung s3 sound does not go to 100 millionths arrow
Old 12-04-2014, 16:44   #9 (permalink)
Member: 893550
Thanks Meter: 139
http://forum.gsmhosting.com/vbb/f258...calls-1530734/
100% solution
but replace this ic carefully
thanks
Old 02-14-2015, 23:37   #10 (permalink)
Member: 2129942
i have samsung i9300 when received a call then the microphone, earphone and its speaker stops working what the problem is possible repair????????
Old 02-16-2015, 21:00   #11 (permalink)
Member: 144223
Thanks Meter: 10
same problem change audio ic
Old 02-23-2015, 08:36   #12 (permalink)
Member: 1519909
reper rf of z3x 100%ok
Page generated in 0.27794 seconds with 8 queries
