10-19-2012, 16:49 | #1 (permalink) |
Junior Member Join Date: Nov 2008 Location: antipolo city
Member: 905453 Status: Offline Thanks Meter: 0 | I9300 S3 no speaker |
10-20-2012, 04:01 | #2 (permalink) | |
Junior Member Join Date: May 2012
Member: 1763229 Status: Offline Thanks Meter: 7 | Quote:
11-07-2012, 15:25 | #4 (permalink) |
Banned Join Date: May 2012 Location: Jeddah, KSA Age: 42
Member: 1759291 Status: Offline Sonork: shajahankt Thanks Meter: 4 | I9300 audio issue solution its 100% hardware issue.. re heat or replace "Audio Codec IC U605" it will work i have expeariance more then 25 same case.. |
The Following User Says Thank You to shajahankt008 For This Useful Post: |
11-26-2012, 23:53 | #6 (permalink) |
Insane Poster Join Date: Jul 2007 Location: Hu/At
Member: 545376 Status: Offline Thanks Meter: 19 | the U605 ic is the AUDIO CODEC IC, this problem can be becouse of the AUDIO IC to. You can found it under, it marked "Aud" on the top of the ic. It is glued. Be carefull! Br: Zsolt |
