02-26-2015, 21:41 | #2 (permalink) |
No Life Poster Join Date: Jan 2013 Location: lebanon
Member: 1869842 Status: Offline Sonork: 100.1625473 Thanks Meter: 186 | Put some bag past flux on all ic Then connect your mobile to power supplie When pressing power button or without you will realise that the shorted ic will dry bag past flux that is used for soldering will melt faster than on other's ic Then check resistors or capacitors if working around the shorted ic if they're not working replace Them If they are working rehot them to make solder melt if your probleme didn't solve than rehot or replace the shorted ic.... |
02-26-2015, 21:42 | #3 (permalink) |
02-26-2015, 21:48 | #4 (permalink) |
Member: 1869842 Status: Offline Sonork: 100.1625473 Thanks Meter: 186 | Put some bga past flux on all ic Then connect your mobile to power supplie When pressing power button or without you will realise that the shorted ic will dry bga past flux that is used for soldering will melt faster than on other's ic Then check resistors or capacitors if working around the shorted ic if they're not working replace Them If they are working rehot them to make solder melt if your probleme didn't solve than rehot or replace the shorted ic....only thanks button |
