12-30-2013, 15:59 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: Palermo
Member: 281998 Status: Offline Thanks Meter: 117 | I9305 audio problem only in call I have a I9305 that works perfectly, except for the call is muted. I also tried inserting the headset and does not work in call, instead it works if I listen to mp3. If I try to record via voice recorder records well. I did a hardreset but nothing, I tried a flash the firmware but the problem remains annoyingly. Help me! |
01-02-2014, 21:18 | #4 (permalink) |
Major Poster Join Date: Nov 2009 Location: Sri Lanka
Member: 1172883 Status: Offline Thanks Meter: 5 | If you flashed it and still not working then it should be with the audio ic. But before that I would advise checking the earpiece and make sure it's properly connected. Changing ic should be the last thing to do. |
06-16-2017, 03:28 | #5 (permalink) |
Insane Poster Join Date: May 2014 Location: DG Khan
Member: 2189830 Status: Offline Sonork: 100.1678166 Thanks Meter: 10 | i9305 no voice during call i change audio ic but same problem mobile water damge plz give the another solution step by step thanks in advance |
