Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 06-13-2015, 23:36   #31 (permalink)
Member: 1701048
Sonork: 100.1655662
Thanks Meter: 17
it can be power button is well when you insert battery if phone vibrate it self its 100% power button
Sent from my iPhone using Tapatalk
Old 06-27-2015, 17:02   #32 (permalink)
Member: 1875267
Sonork: ....
Originally Posted by diljit07 View Post
i have samsung i9505 when i connect to charger its become very hot
not found which part is short
get mother board connect with battery and insert charger. touch to power ic.
Old 07-07-2015, 13:35   #33 (permalink)
Member: 2148186
Sonork: 100.1653763
i have same problem with u !
Old 07-07-2015, 13:47   #34 (permalink)
Member: 2148186
Sonork: 100.1653763
Originally Posted by SHIBU13 View Post
i9500 when i connect to power supply show 1.2v amp when power key is pressed & to 0 (zero) if power key is released. pcb seems fresh no water entry or physical damage.
i have same problem here !
Old 07-13-2015, 11:16   #35 (permalink)
Member: 1790220
Red face I9500 no power
I have a samsung s4 i9500 which is not powering on, when connecting to power supply it doesn't consume any power, when pressing power switch it shows about 0.28A on the power supply for a second then going back to zero Amps.
when connecting to laptop usb port it doesn't show any thing at all on both sides laptop and mobile.
when connecting to charger ucp5000 (exynos) ic is getting very hot.
should i change power IC (U600) in this case???
or it is a faulty emmc???
plzz reply...
Old 07-13-2015, 22:33   #36 (permalink)
Member: 2204348
Thanks Meter: 2
plzz reply...
Same problem here...............
Old 07-15-2015, 10:06   #37 (permalink)
Member: 1790220
same problem
I have tried changing both ICs MAX77803 and the power management IC S2MPS11.
I still have the same result, but now when I press the power button, the current raise from zero to 0.11 amps instead of 0.28 amps
note that the current raise only while I'm pressing the power button, it goes back to zero directly after releasing the power button.
any help plz....
Old 07-27-2015, 08:52   #38 (permalink)
Member: 194092
Thanks Meter: 6
same problem for me: 0.05a
desoldering c835 i've no amp: ill try to replace pm8917 right?
Old 07-27-2015, 12:14   #39 (permalink)
naushad09's Avatar
Member: 216094
Thanks Meter: 321
I Have Done Handset By Remove Wifi Ic
Regard's
Naushad Ali
Old 07-29-2015, 20:53   #40 (permalink)
Member: 2436368
Hi I checked and the IC is very hot, should I remove this or maybe is some capacitor fault which can making different voltage?
Old 10-14-2015, 10:41   #41 (permalink)
Member: 1863898
Thanks Meter: 4
Hello same problem here with galaxy s5 sm-g900f. 0.05A short and when pluge charger it becomes hot, help me to fix this thanks
Old 10-16-2015, 02:01   #42 (permalink)
israrbjr's Avatar
Member: 748544
Sonork: 100.1601881
Thanks Meter: 173
after a long research and fix about 100 phone 90 % this problem com from power i.c
Old 10-17-2015, 09:21   #43 (permalink)
Crazy Poster
Member: 175617
Thanks Meter: 20
hi guys.. NAUSHAD ALI IS correct most of the S4 unit cannot on or shorted just remove the WIFI IC.. but some s4 must change also the PMIC together with WIFI Ic.. 101% guys done many units.. have a nice day
The Following User Says Thank You to joicute For This Useful Post:
Old 10-30-2015, 17:56   #44 (permalink)
Registered User
Member: 1423542
Thanks Meter: 32
Hi guys, i have one Samsung I9505 and alredy change the power ic, but when i turn on, appears samsung S4 I9505, but he stuck there, any solution??? and what component is damage?
Old 11-05-2015, 13:09   #45 (permalink)
Member: 480405
Thanks Meter: 36
same to me phone power on conect charger only, after power on no audio ,after power on werking power phone but no sound ,with out charger power on no power 0.05 mah what to do?
Page generated in 0.21894 seconds with 9 queries
