Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 12-04-2013, 11:12   #1 (permalink)
unlock.mk's Avatar
Member: 1671934
Thanks Meter: 243
i9500 i9505 - not power on (hardware)
-Condition: Not power on
-i9505 Board attached to power supply shows 0.05 A.
-When power ON button pressed "A" not changing. stays on 0.05A.
-How to find which capacitor is shorted,
-maybe problem is in i9505 power IC ?
Solution, some kind of ?
The Following 5 Users Say Thank You to unlock.mk For This Useful Post:
Old 12-04-2013, 11:47   #2 (permalink)
unlock.mk's Avatar
Member: 1671934
Thanks Meter: 243
I got to mention 3 things more:
- On battery or charger connected, board becomes very hot.
- Riff box does't recognise this phone at all
- PC doesn't recognise phone eather.
Old 12-04-2013, 12:46   #3 (permalink)
unlock.mk's Avatar
Member: 1671934
Thanks Meter: 243
Work progress made.
- Power IC reballed, result same.
Old 12-04-2013, 14:00   #4 (permalink)
d-Artigo's Avatar
Member: 1573913
Sonork: hardware illustration
Thanks Meter: 5,937
samsung gt-i9505 turn on problem
1. check or replace the two capacitors C835 and C838 (number 1)
(Repeated measure with avo meter or psu)
2. if the charger is still hot when in his third locker) number 2)
see the image below:
only thank button
The Following 4 Users Say Thank You to d-Artigo For This Useful Post:
Old 12-04-2013, 14:23   #5 (permalink)
Ionel's Avatar
Member: 81232
Thanks Meter: 184
I would check if there is voltage on power button , change the power ic , if there was an short on pcb , there will be high current consuption on power suply , check if quartz freqvency is ok.
The Following User Says Thank You to Ionel For This Useful Post:
Old 03-24-2014, 20:17   #6 (permalink)
Member: 1607116
Sonork: 100.1617729
Thanks Meter: 45
replace Ic Power!!!!
Old 03-24-2014, 22:16   #7 (permalink)
Member: 730798
Thanks Meter: 43
Put battery in, then connect via USB cable to PC,
IF PC will not show you a new hardware found your problem is POWER IC SUPERVISOR U800
Old 05-08-2014, 11:12   #8 (permalink)
raselopu's Avatar
Member: 485407
Sonork: 100.1580486
Thanks Meter: 181
Common problem but no solution !
Old 06-10-2014, 12:40   #9 (permalink)
czaren's Avatar
Member: 735013
Thanks Meter: 74
i just want to confirm from you,I replaced the power IC and it works.
First thing i did was removing charging ic,the short gone but when I return it back even with other harging ic,the short return back also,so I decided to replaced the power ic, not reball.Must be replaced directly.
Old 06-19-2014, 15:18   #10 (permalink)
raselopu's Avatar
Member: 485407
Sonork: 100.1580486
Thanks Meter: 181
thanks for your kind reply.
Changed power ic and it's same short 0.05A with no power switch responce...i9505.
Old 08-26-2014, 16:47   #11 (permalink)
Moderator
chand_gee's Avatar
Member: 668050
Sonork: 100.1656307
Thanks Meter: 716
any one solve this problem?
i9500 same symptoms
when putt charger charging ic heatup no response power button
changed charging ic
changed power ic
removed many capacitors
power button have 4v but when i press voltage dropped to 1v
no power
Old 08-28-2014, 00:27   #12 (permalink)
Member: 1911256
Sonork: reshikadeo
hi i have a samsung gt-i9505 speaker not working. i have replaced new speaker, still not responding. tested with new sub pcb, still not responding. plzzzzzzzzzzzzzzzzzzzzzz help
Old 10-08-2014, 10:23   #13 (permalink)
Member: 1873863
Thanks Meter: 67
Hi ! i am entering in your same club...
i have received an i9505 with the same problem, when i connect power supply to battery terminal, it goes to 0.04a - 0.05a consumption and doesn't power on.
If i press power button, nothing happen.
Tried to replace MAX power ic... nothing.
Reballed U800... nothing.
Many voltage missing, especially S4_1P8 which is very important.
Old 11-21-2014, 04:48   #14 (permalink)
Member: 1227890
Sonork: 100.1612890
Thanks Meter: 14
sir try to remove this...hope its help
The Following User Says Thank You to denrich24 For This Useful Post:
Old 11-21-2014, 18:33   #15 (permalink)
Member: 2237030
Thanks Meter: 9
If the current 50ma that means the VPH _PWR line shorted most of the cases,(you can check it easily wit multi meter) so all the components which use this voltage can be faulty.
Some times very easy to fund the faulty components when it is a capacitor, because its burning or damading itself.
My suggestion:
1. Look through the whole main board (with microscope) and if you fund a burned, broken capacitor just broke it down
2. Remove the U800 and give 4 volts to the output VPH _PWR with your powersuply, in this case the shorted components gonna heating up (be careful because it will be very hot)
The Following 2 Users Say Thank You to hhto For This Useful Post:
Page generated in 0.38363 seconds with 8 queries
