12-01-2013, 06:11 | #2 (permalink) | |
No Life Poster Join Date: May 2011 Location: gsm-forum
Member: 1573913 Status: Offline Sonork: hardware illustration Thanks Meter: 7,629 | Quote:
samsung gt-i9500 s4 no charging 1. try cleaning the sub pcb connectors HEA1001 of corrosion 2. C1030 jumper connector to 12 pin sub pcb 3. replace usb charging port flex ribbon if the above is still working through the stages as before: rehot or change ic analog U1003 see the picture below only thank button | |
08-28-2015, 15:22 | #7 (permalink) |
Junior Member Join Date: Aug 2015
Member: 2449627 Status: Offline Sonork: 100.1668716 Thanks Meter: 0 | i have a galaxy s6 edge that fell down in the water. i cleaned it with alcohol, and after i try to charge it, but it gives error battery temretureis too low. what should i do? |
