Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 03-22-2014, 16:49   #1 (permalink)
Member: 480405
Thanks Meter: 36
i9505 camera fail
my i9505 camera is fail ,i try flash new version,after cheng new one but still same problam plz help enybody
Old 03-24-2014, 00:55   #2 (permalink)
Member: 1894707
Sonork: 100.1658432
Thanks Meter: 51
that seems like a hardware fault on camera. The flex might be disconnected at its least possibility.
Try replacing camera itself.
If you happened to check front camera too? if it works?
Old 03-24-2014, 16:27   #3 (permalink)
Member: 480405
Thanks Meter: 36
front camera is working but back camera not work , i was replace new one but same
Old 03-24-2014, 16:38   #4 (permalink)
biaby's Avatar
Member: 523332
Thanks Meter: 273
dial : *#0#
and test the mega cam to see if camera work or not then post reply please,
Old 03-24-2014, 22:17   #5 (permalink)
Member: 730798
Thanks Meter: 48
I thins is IC-CAMERA problem
Old 03-25-2014, 08:08   #6 (permalink)
Member: 730798
Thanks Meter: 48
IC-CAMERA is on the PBA, this is not a camera.
Old 03-27-2014, 07:06   #7 (permalink)
Member: 480405
Thanks Meter: 36
how to repeair this problam
Old 03-27-2014, 16:18   #8 (permalink)
Member: 480405
Thanks Meter: 36
enter code *#0*# after give massege data line fail after camera fail
Old 03-28-2014, 17:59   #9 (permalink)
Member: 598249
Thanks Meter: 154
first check with new cam
if same then clean camera connector with ctc
if still same then check these parts..
The Following User Says Thank You to ikhan9323 For This Useful Post:
Old 03-28-2014, 18:07   #10 (permalink)
Member: 2069548
Try the phone without front camera
Old 04-12-2014, 15:33   #11 (permalink)
Member: 480405
Thanks Meter: 36
i try but not work camera
Old 06-04-2014, 22:11   #12 (permalink)
Member: 1283794
Thanks Meter: 3
something new? have you managed to repair the camera? someone else with the same problem, who repaired the camera? I have one too. I am curious, generaly, what's the problem? hardware? software?
Old 11-28-2014, 14:09   #13 (permalink)
Member: 82886
Sonork: adyblana
Thanks Meter: 8
if the front camera its broken ,rear camera give eror.tested by me
The Following User Says Thank You to AdyBlana For This Useful Post:
Old 04-26-2016, 10:25   #14 (permalink)
Member: 82476
Thanks Meter: 4
Yes is true! The front camera was broken, and replacing it dose the job.
Thanks.
Page generated in 0.23186 seconds with 9 queries
