10-12-2013, 23:19 | #3 (permalink) |
Freak Poster Join Date: Feb 2010
Member: 1240599 Status: Offline Thanks Meter: 11 | Change charging block before any board work. Simple to replace and solved at least 4 i9505 with same problem for me |
The Following User Says Thank You to alexlikedit For This Useful Post: |
04-04-2014, 16:28 | #5 (permalink) |
No Life Poster Join Date: Nov 2002
Member: 17362 Status: Offline Thanks Meter: 242 | I have a Samsung s4 Gt-i9500 Has " charging paused battery temperature too low" I did the following; 1. I replaced the entire USB charging flex assembly ribbon 2. Master reset & Clear cache 3. Upgraded phone via kies 4. New Battery 5. New Charger and still I have this problem... |
The Following User Says Thank You to gsm1999 For This Useful Post: |
05-24-2014, 19:17 | #7 (permalink) |
Freak Poster Join Date: Apr 2007 Location: Millionaire Club ™
Member: 487562 Status: Offline Thanks Meter: 111 | same problem here: U908 - small one - OK (5V in and 5V out) U903 (max7788) replaced from other S4) charge/usb socket OK, batteries fine... anyone know where is that temperature sensor (or how to switch it OFF in sw.) any help appreciated!!! "Chargeing paused. Batery temperature too low" BR spherus |
05-25-2014, 05:38 | #8 (permalink) | |
No Life Poster Join Date: May 2011 Location: gsm-forum
Member: 1573913 Status: Offline Sonork: hardware illustration Thanks Meter: 7,628 | Quote:
samsung gt-i9505 charging paused by temperature see image below ( re-upload ) : only thank button | |
The Following 4 Users Say Thank You to d-Artigo For This Useful Post: |
03-19-2015, 08:52 | #14 (permalink) |
Freak Poster Join Date: Jul 2005 Location: Romania Age: 41
Member: 163459 Status: Offline Thanks Meter: 33 | My problem solved by replacing the entire USB charging flex assembly and the conector on the board. i hope will help for you too, thx for everybody! |
