03-31-2009, 20:02 | #3 (permalink) | |
Junior Member Join Date: Mar 2009
Member: 999291 Status: Offline Thanks Meter: 1 | Quote:
This method is maybe known for some of you , i test it for some models (like E250 ,J700 ..) and i think , it can work for all other models .. It's easy ,no risk at all , no cable , no drivers , but need to be handled well Today i test it on J700 , as we know ,many of us have a bad result after using box to unlock that fone ,, (bad Imei ,bad BT adress ... ) but with this method ,, EVERYTHING is FiNe 1- Power on fone ,, type : *#7465625# you will identify wich code is active , wich is inactive 2- Remove battery ,, Put your sim card , not all of it ,, just to prepare it to be full inserted , put your battery back and power on fone ,, you must see " insert sim" not "invalid sim.." 3- type : *2767*3855# your fone should restart after 1 min ,, now ,, and before it restart , push your sim card ,,without removing battery 4- your fone should work and accept the sim card ,, but if you chek locks you will find that your fone is still Loked 5- now type : *7465685*638*00000000*00000000# your UNLOCK CODE is 00000000 now , hh Enjoy 6- now , back to Locks table with : *#7465625# ,, and for each active code you can disable it ,,,here details : * Disables CP lock : #7465625*27*00000000# * Disables Network lock : #7465625*638*00000000# * Disables SIM lock : #7465625*746*00000000# * Disables SP lock : #7465625*77*00000000# * Disables Subset lock : #7465625*782*00000000# I wish It help , Regards | |
The Following User Says Thank You to sonicemale For This Useful Post: |
j700 insert sim ((good solution)) | MMDEBILI | Samsung Hardware Repair | 10 | 06-17-2012 08:22 |
j700 insert sim | ntek | Samsung Hardware Repair | 21 | 08-04-2011 17:01 |
help j700 insert sim | xp_zone | Samsung Hardware Repair | 3 | 04-12-2011 07:44 |
j700 insert sim | vinkle | Samsung Hardware Repair | 4 | 10-23-2009 11:57 |
3210 - "Insert SIM", but SIM is inserted !?! | MaRiN | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 12-29-2000 17:08 |
