10-11-2003, 11:28 | #1 (permalink) |
No Life Poster Join Date: Nov 2002 Location: Nigeria
Member: 18200 Status: Offline Sonork: 100.1608286 Thanks Meter: 82 | Many Samsung Phones Damaged By Hi Voltage While Charging Solution with either of this fault: EITHER dead by too much voltage while charging OR even though the charging indicator is moving, It still does not charge. Now I know that definetely, the over voltage has damaged a component on the PCB; So I want to know which components are damaged as follows: 1. When the phone is completely dead, which components were killed? 2. When the phone is still alive, but does not take charge anymore, although the charging indicator is moving when charger is connected, which components do I change ? Thanks in advance. dannyogolo |
The Following 2 Users Say Thank You to dannyogolo For This Useful Post: |
10-11-2003, 12:25 | #2 (permalink) |
No Life Poster Join Date: Dec 2001 Location: Ukraine Age: 46
Member: 7767 Status: Offline Thanks Meter: 3 | LTC1734ES6 (TRG on element) - 6 legs - 1 and 3 shorted - no charge, but indicator show charging Transistor 2SB1427 (P20D on element) - 6 legs (R210), 3 legs (N620) - short - no power up Capacitor 10 UF 10 V - burned Mostly LTC1734ES6 dead |
10-11-2003, 16:55 | #3 (permalink) |
Member: 18200 Status: Offline Sonork: 100.1608286 Thanks Meter: 82 | That is good news, Man Chuk, Even if I have not tried them out, the way you say them, you seem to know what you are saying. I wish they work. Thanks anyway. dannyogolo |
10-13-2003, 09:59 | #4 (permalink) | |
No Life Poster Join Date: Sep 2001 Location: Bosnia and Herzegovina Age: 50
Member: 6464 Status: Offline Thanks Meter: 6 | Quote:
But,I have problems to find replacements,do know where (on which phone except samsung) to find it? Thanks Regards | |
10-13-2003, 13:29 | #5 (permalink) | |
No Life Poster Join Date: Jan 2002 Location: MARS
Member: 8304 Status: Offline Thanks Meter: 362 | Quote:
11-15-2003, 15:19 | #7 (permalink) |
Member: 7767 Status: Offline Thanks Meter: 3 | One correction: LTRG 1 and 3 must be short. If not - result show charging, but not charge. Other damages of LTRG and P20D - no power off, no charging, charging without charger (phone warm) Ofcourse in some cases not only LTRG and P20D damaged. Reason of uprated current consumption can be PA, CPU, capacitors and other parts which use Vbat directly. |
11-15-2003, 18:19 | #8 (permalink) | |
No Life Poster Join Date: Aug 2001 Location: P A K I S T A N _____________ Age: 40
Member: 5932 Status: Offline Thanks Meter: 1,694 | Quote:
@CHUK.. u r 100@ right.. I also repair everyday lot of SAMSUNG R220, N620 and T100 for the above solutions.. But I have one problem and don't found a solution.. I received many V200 from diffrent customers thay become dead.. and its CPU get heat up... can u tell me where maybe the problem.. or we have to replace CPU. its seem common problem.. becaise I received many but we can;t repair it. Best Regards, Wahab | |
11-24-2003, 10:14 | #9 (permalink) |
Insane Poster Join Date: Jan 2001 Location: Latvia Age: 52
Member: 3022 Status: Offline Thanks Meter: 1 | The sometime reason of this failures is using by customer a charger from LG phones which have the same connector, as result in good case we have damaged protection part in bad case we have damaged CPU |
11-24-2003, 12:13 | #10 (permalink) |
Member: 7767 Status: Offline Thanks Meter: 3 | To DrMobile: I don't have V200 with such ptoblem yet, but I see C100 with same problem - CPU very hot and current consumption more than 1.5 A . I think that CPU damaged. |
02-17-2004, 13:24 | #13 (permalink) |
Insane Poster Join Date: Jul 2003
Member: 33029 Status: Offline Thanks Meter: 9 | S300 consume power Hi!All the forum members,Need advice from u guys,S300 consume power when turn on test it using power supply.No experience in repairing this phone,a friend of mine said it might be cap leakage,please advice.Thanks in advance. |
07-02-2004, 01:16 | #14 (permalink) |
Freak Poster Join Date: Dec 2002 Age: 39
Member: 18577 Status: Offline Thanks Meter: 4 | HI All Whatever the problem is but i didnt got a solution to myself. My bro connected Lg Charger to the phone and it went dead withing 10sec and also the phone went hot. Later he connected the original samsung charger, and than again the phone got heated uo. After that when i connected the charger nothing happened. When i opened the phone, and after a lot of moving here and there stuffs i found the cpu to be short, but dont have any spare of it to replace. Never though a mere charger could be such a panic. regards Ayush *** NEVER USE OTHER PHONE STUFFS FOR YOUR PHONES *** |
07-02-2004, 11:50 | #15 (permalink) | |
No Life Poster Join Date: Apr 2003 Location: Bled lekhla
Member: 27291 Status: Offline Thanks Meter: 81 | Quote:
I have a V200 Dead after using bad charger ! I changed the MTRG P20D and make this shurt circuit gave by alex123 but no Thing !! When I push the power on button The Pwer supply make the indicator to 0.4 watt and V3.7V But doesn't power on ? what can be the solut please ? | |
samsung p910 damage after changing charge connector | fethi | Samsung Hardware Repair | 2 | 01-01-2010 21:26 |
Solution For N85 Rebooting While Charging... | jafsupport.com | J.A.F. By Jafsupport.com | 0 | 02-16-2009 20:02 |
Samsung T500 Short Circuit by Big Voltage, PLease Help ! | MT_LBN | Samsung Hardware Repair | 0 | 02-16-2006 12:40 |
C55 dead after hi voltage :( | yohoho | E-Gold Based Phones | 0 | 06-20-2003 15:00 |
Help!Phone turns off while charging at 80%(after ME45 to ME45i). | Witek | x1x to x45/x50 | 2 | 10-20-2002 16:10 |
