10-31-2006, 19:05 | #3 (permalink) | |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | Quote:
first check data interface jack means charging connector , in samsung most cases of system failure is due to that damm conn. you have to clean very well or replaced conn if not ok then it's a fault of flash ic you have to change flash ic & full flash the phone & rebuild IMEI Good Luck | |
11-08-2006, 15:06 | #4 (permalink) |
Freak Poster Join Date: Oct 2005 Location: jogjakarta Indonesia Age: 46
Member: 192822 Status: Offline Thanks Meter: 18 | Hi Friend first check data interface jack means charging connector , in samsung most cases of system failure is due to that damm conn. you have to clean very well or replaced conn if not ok then it's a fault of flash ic you have to change flash ic & full flash the phone & rebuild IMEI Good Luck[/quote] which software do you use friend for repair system failure? as i know ufs cannot repair this case. me have one problem like this and cant solved. thanks fastlink |
11-09-2006, 19:18 | #6 (permalink) |
Insane Poster Join Date: Apr 2005 Age: 47
Member: 136633 Status: Offline Thanks Meter: 3 | hi it is the charging connector those capasitors that attach the data pins and the arc remove them all and it will work i did it for a lot of samsong 100% ok try it good luck. |
N620 System Failure Contact Provider | nadeem786 | VLSI, Conexant, Skyworks and Old Models | 16 | 07-19-2007 05:11 |
r210s System Failure contact provider | SoftSkiner | VLSI, Conexant, Skyworks and Old Models | 4 | 11-28-2005 15:40 |
N620 - System Failure Contact Provider | sp-lox | VLSI, Conexant, Skyworks and Old Models | 3 | 04-19-2003 15:14 |
N620 System Failure Contact Provider | X-Treme | VLSI, Conexant, Skyworks and Old Models | 21 | 11-18-2002 22:54 |
N620 System Failure Contact Provider | terryzs | VLSI, Conexant, Skyworks and Old Models | 1 | 06-26-2002 12:41 |
