11-07-2014, 22:23 | #1 (permalink) |
Banned Join Date: Jul 2011 Location: IRAN-KARAJ
Member: 1616463 Status: Offline Sonork: 100.1660594 Thanks Meter: 247 | N7000 Problem after changing eMMC I received a dead n7000. I changed it's emmc. Now it boots on and receive calls and everything but it has a black screen. I have changed it's LCD and checked everything on display way on the board and also tried different firmwares. Do anyone have an idea? i've heard that i should replace a resistor! Please share if you have a solution... |
11-08-2014, 01:16 | #3 (permalink) | |
Freak Poster Join Date: Dec 2011 Location: Russia, North Ural Age: 68
Member: 1702061 Status: Offline Sonork: 100.1651562 Thanks Meter: 306 | Quote:
Check Vbat at both ends of L505 | |
The Following 2 Users Say Thank You to KorAll For This Useful Post: |
11-08-2014, 21:53 | #5 (permalink) |
Member: 1702061 Status: Offline Sonork: 100.1651562 Thanks Meter: 306 | Check all elements near U509. They all must be good, except "cold solder". Check R519. Last edited by KorAll; 11-08-2014 at 21:59. |
11-09-2014, 18:05 | #9 (permalink) |
Member: 1702061 Status: Offline Sonork: 100.1651562 Thanks Meter: 306 | Hey, guys. It is the very simple to check this U509 ic with m/meter. Look: 1. Check Vbat at pin 1 and pin 10 of this ic. If absent, check R519. This R519 have direct way to (+Vbat) connector phone PCB. May do jumper from R519 to (+Vbat) if necessary. 2. Check ways from pin 3 to C502, from pin 8 to C503. If all OK, than next. 3. M/meter mode - diode check. Negative wire to phone ground, positive wire to pin 4 of U509 and see: a) if lsd shine, it mean bad EL_ON signal. b) lcd not shine - it mean bad U509. |
11-11-2014, 07:09 | #11 (permalink) |
Member: 1616463 Status: Offline Sonork: 100.1660594 Thanks Meter: 247 | As i mentioned in my first post i have already checked the lcd way and none of answers above helped. I changed eMMC and now its working properly. Thanks anyway |
The Following User Says Thank You to meshkat_azizi For This Useful Post: |
11-14-2014, 13:33 | #12 (permalink) | |
Junior Member Join Date: Nov 2014
Member: 2292461 Status: Offline Thanks Meter: 1 | Quote:
11-16-2014, 21:12 | #14 (permalink) |
Member: 2294116 Status: Offline Thanks Meter: 1 | EL_ON restore hello guys i want to restore EL_ON line my lcd had shined but i want to know where the EL_ON command comes from???? i have searched the schematics but with no hope. does any body know ??? waiting for reply thanks. |
11-17-2014, 17:57 | #15 (permalink) | |
And next info from service manual - Component placement - Post your additional questions if necessary. Don't forget about thank button | |
