10-21-2015, 21:01 | #1 (permalink) |
Junior Member Join Date: Oct 2015
Member: 2476199 Status: Offline Thanks Meter: 0 | Glass Replacement I want to replace my damaged glass from my I9505.I have seen many guides/videos how to do that, but I have some questions about the adhesive between the screen and the digitizer: 1)Some people remove the old adhesive by rubbing it and cleaning with isopropyl alcohol. Others use specialized remover. Which one would you suggest? Is there any chance that the remover solvent will damage the digitizer? 2)There are many UV LOCA adhesives: TP-1000,TP-2500, Octopus glue. Do you have any experience with them? 3)Is there a requirement about the power of the UV Lamp? There are lamps rated at range 10W-50W. Thank you for your time |
