08-22-2015, 01:08 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: karachi
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | n900a suddenly no power (need help) previously power on when press lcd connecter and after resold lcd connecter on pcb it works fine but now not power no vibration no charging |
09-06-2015, 06:41 | #3 (permalink) | |
Junior Member Join Date: Sep 2015 Age: 53
Member: 2454989 Status: Offline Thanks Meter: 0 | Quote:
Sent from my SM-N900P using Tapatalk | |
09-06-2015, 21:56 | #10 (permalink) |
Member: 2454989 Status: Offline Thanks Meter: 0 | It seems they have sent you the wrong one. I have replace my charging port on my phone. I had the wrong one at first but then received the right one. If you are thinking about changing the charging port you need to make sure you use the sticker that comes with it if you have Sprint as your service. I am Not sure how to do the other ones. If I were you I would send back that piece and ask for another one. Make sure you give them the correct information on what type of phone that you have. Sent from my SM-N900P using Tapatalk |
09-11-2015, 06:12 | #11 (permalink) |
No Life Poster Join Date: Mar 2003 Location: INDIA Age: 57
Member: 25662 Status: Offline Thanks Meter: 190 | [QUOTE=HUM;11270594 one component missing form here QUOTE] this IC is sensor not responsible for power on. check without lcd connected and power on and connect to pc. on lcd connector 1.8v volt is most imp. if its shorted than it will not power on. check with same model lcd. Go through trouble shooting check voltage |
09-12-2015, 11:06 | #13 (permalink) |
No Life Poster Join Date: May 2011 Location: gsm-forum
Member: 1573913 Status: Offline Sonork: hardware illustration Thanks Meter: 7,629 | |
09-22-2015, 01:06 | #15 (permalink) |
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | share ur expertise first camera problem now abnormal power and abnormal display wat u think its power ic problem ? now it take 2-3 amp |
