12-23-2015, 04:50 | #1 (permalink) |
Crazy Poster Join Date: Oct 2014
Member: 2272978 Status: Offline Thanks Meter: 5 | N910 note 4 dead tryed to repair failed need help Before every repair test i get this value When i buy, connected to power supply 0.00 A pushing power button 0.00 A Changed the big power ic i get 0.00 A pushing power button 0.10A but when release return to 0.00A Changed MPB01 (small power supply) and small power ic ( max77843 ) when connected get 0.01A when push button and stay pushed 0.94A when release return to 0.01A Can anyone help me? |
12-23-2015, 18:43 | #2 (permalink) |
Insane Poster Join Date: Aug 2012
Member: 1803209 Status: Offline Thanks Meter: 10 | hi i am also having the same problem My phone is not water damaged i think but i bought it used it was working fine suddenly it started rebooting again and again after 3-5 minutes thn it stopped charging and when i rehot the MPB01 it just went DEAD....i have replaced MPB01 ..the big power ic also ...the baseband power ic also but not the MAX77843...i apply 4.1 voltage and push the power button the current is stuck at 0.44 and some times 0.07 sometimes 0.38 ...i dont know what to do with it if anyone has the solution kindly tell us thanks |
01-16-2016, 19:40 | #6 (permalink) |
No Life Poster Join Date: Jan 2013 Location: lebanon
Member: 1869842 Status: Offline Sonork: 100.1625473 Thanks Meter: 186 | Well can't find a schematic for your phone But check capacitors/diodes/ resistors /coils arround ic power if shorted or cracked and replace Probleme didn't solved Rehot or replace emmc ic |
The Following User Says Thank You to habibboxes For This Useful Post: |
01-23-2016, 00:05 | #7 (permalink) |
Member: 1803209 Status: Offline Thanks Meter: 10 | hi thanks for the reply but are you sure it is related to the emmc? the phone is not even booting and i have checkd all the coils and resistors diodes etc near all the power ic's...before changing the power ic at the back of the processor it was booting but used to get stuck but when i rehotted the power ic behind the cpu with very less heat it never booted again |
