09-20-2018, 03:57 | #1 (permalink) |
Junior Member Join Date: Apr 2014
Member: 2162337 Status: Offline Thanks Meter: 0 | N910s korean note 4 replacement charging port Thanks in advance |
09-20-2018, 05:25 | #2 (permalink) | |
No Life Poster Join Date: May 2011 Location: gsm-forum
Member: 1573913 Status: Offline Sonork: hardware illustration Thanks Meter: 7,629 | Quote:
charging usb port dock connector charger port is the same as or compatible for samsung galaxy Note4 N910F N910S N910W8 | |
The Following User Says Thank You to d-Artigo For This Useful Post: |
09-20-2018, 06:01 | #3 (permalink) | |
Member: 2162337 Status: Offline Thanks Meter: 0 | Quote:
Thank you.. I will buy a n910f usb port and gonna give it a try. Will post for feedback once I replace my broken one.. Will there be any problem like signal loss or mic problem once I replaced it? | |
09-20-2018, 11:21 | #4 (permalink) |
Member: 2162337 Status: Offline Thanks Meter: 0 | I doubt it would work since n910f uses qualcom while n910s uses exynos board.. Will I ended up frying my board if I use different charging pin/ flex in my n910s using from different variAnt? |
