10-07-2004, 14:13 | #1 (permalink) |
Insane Poster Join Date: Oct 2004 Location: Lagos, Nigeria Age: 51
Member: 84978 Status: Offline Thanks Meter: 1 | need help for r220 limited service |
10-08-2004, 11:06 | #2 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Bled lekhla
Member: 27291 Status: Offline Thanks Meter: 81 | First Flalash the phone with a good flash if not write eeprom and IMEI reset eeprom If not Check the contact (antenna-motherboard) if not change Switch antenna if no change PA That's All |
10-08-2004, 13:24 | #3 (permalink) |
No Life Poster Join Date: Mar 2004 Location: Pakistan Age: 42
Member: 56561 Status: Offline Sonork: 100.114006 Thanks Meter: 41 | Rehot the EEPROM....and write new EEPROM...Or try to reset uor phone using Tool box 5........................... WBR Imran Khatri |
10-08-2004, 13:32 | #4 (permalink) | |
No Life Poster Join Date: Sep 2001 Location: London, UK
Member: 6486 Status: Offline Sonork: 100.79846 Thanks Meter: 350 | Quote:
clean and resold the external / internal an****a properly as well! BEST REGARDS GOHAR | |
10-08-2004, 13:50 | #5 (permalink) |
Freak Poster Join Date: Oct 2003 Location: GSM Center Ro ******** Age: 44
Member: 41900 Status: Offline Thanks Meter: 2 | first of all ......... i solved a problem like this with eeprom reset *2767*2878# or *2767*3855# if not working change PA, if you solve problem post with what solution... |
10-10-2004, 14:57 | #6 (permalink) |
Freak Poster Join Date: Jul 2004 Age: 42
Member: 71960 Status: Offline Thanks Meter: 5 | check this out too..... above solutions not solve your problem try to replace or short circuit little capacitor under the pa.onece in my case lost(thought drop phone) that cap gave me half day work.but that condition 1800mhz operator would display but can't make call(call end) 900mhz sim with signal ok but limitted serevice. post result, good luck. |
10-11-2004, 12:30 | #7 (permalink) |
Member: 84978 Status: Offline Thanks Meter: 1 | I have flashed the phone and reset eprom, but problem persist. pls where is the PA in the the motherboard so i can change it to see if problem will solve. (what is PA) am newbie in the gsm stuff. |
11-26-2004, 14:16 | #8 (permalink) |
Freak Poster Join Date: Feb 2004 Location: noWhere Age: 45
Member: 52810 Status: Offline Thanks Meter: 19 | check the SM for r220 this is R220E not R220 and i dont know if they are the same hardware or not but it could help http://www.moviltuning.net/downloads...H-R220E_SM.zip |
12-22-2004, 20:14 | #9 (permalink) | |
Insane Poster Join Date: Oct 2004 Location: bhopal Age: 51
Member: 85008 Status: Offline Thanks Meter: 4 | Quote:
or just connect juper from mother board to antenna as this is common fault in r220 as i have solved many pc by this procedure | |
02-15-2005, 17:30 | #12 (permalink) |
No Life Poster Join Date: Dec 2002 Location: nigeria
Member: 18926 Status: Offline Sonork: ndagi Thanks Meter: 52 | @btl he means(singapore), a jumper from antenna contact on board to antenna! meanwhile, this proble often lies in the careless handling of the phone by another technician maybe while trying to change the casing. in 98% of the cases i've solved you'd find a missing component in the network section of the pcb which should be replaced first with the exact component from a scrap board. if problem persists then, flash eeprom with ust5.6 craked eprom pack for all vlsi model available freely on the net. 100% working for me 100 times and with all vlsi models! for agere platforms especially A300 and A400, full flash with good firmware (after checking for hardware alterations that is) and please replace copper plate that where originally there in the inner back casing. this too has worked 100 time perfectly. i hope this has been helpful. |
12-30-2005, 02:39 | #13 (permalink) |
Cheater -Don't Deal with him- Join Date: Aug 2005 Location: /%%temp%%.;adb
Member: 172434 Status: Offline Sonork: 100.161280 Thanks Meter: 577 | 100% I hav been enjoying such jobs, what i do is this, first read the external antenna jack two points, if not working, use a tiny copper wire to cross it, must not touch the gnd, then check by the three black ics by up left, if no resistor missing by the side, apply sodering paste under the ics terminer and resorder, it must repent. |
01-25-2006, 08:45 | #15 (permalink) | |
Crazy Poster Join Date: Dec 2005
Member: 215196 Status: Offline Thanks Meter: 2 | Quote:
The Following User Says Thank You to adgraf For This Useful Post: |
i need help for 5130 contact service | chronic | Nokia Base Band 5 ( BB-5 ) | 6 | 07-24-2009 10:23 |
Need Help For R220 Insart SIM | hossnemamun | Samsung Hardware Repair | 2 | 07-09-2009 10:30 |
Need Help for Imate Jam Service manual/diagram | small_world | HTC & PDA WM( With Touchscreen) | 1 | 05-14-2007 08:51 |
Off Topic, Need help for NOKIA 252 service problem!! | bre786 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 10-24-2001 12:51 |
Plz i need help for 8850 contact service | CHATAR | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 16 | 05-06-2001 16:34 |
