07-15-2008, 20:40 | #1 (permalink) |
No Life Poster Join Date: May 2005 Age: 43
Member: 149032 Status: Offline Thanks Meter: 3,808 | NsPro Problems-Solutions by alex12345 Here are descriptions of NsPro error messages and solutions for that ewrrors: NsPro Axalto card not found (error 0x01) = Smartcard is not detected by windows. Solutions: 1.Check if smartcard drivers are correctly installed. A new version of smartcard drivers can be found HERE 2.Check if the card is correctly connected into the card reader inside the box. NsPro Axalto card not found (error 0x02) = corrupted card NsPro Axalto card not found (error 0x03) = corrupted card Solution: Can be repaired by using this software NsPro Axalto card not found (error 0x04) = damaged card Solution: Send the card back to reseller or distribuitor - unlockcellular.com : for replacement NsPro box /port not found... Solution: Install the drivers from Program Files\NsPro\NsPro Driver folder from your PC Runtime error Solution: Reinstall last software version and confirm all installation steps. If problem persist, go to Program Files\NsPro\NsPro Driver folder and import "Exception.reg" file into windows Regedit tool Connection Establishing failed 100xx Allow from firewall to NsPro to connect to internet (server) for updating the card Update not allowed on NsMultiUnlock = you have not buyed NsMultiUnlock activation. After you buy activation and reseller will activate your card ID on server, you will be able to run the software. |
..:: 11 model nokia mmc ic problem solution by zeking82::.. | zeking82 | Nokia Hardware & Hardware Repair | 21 | 02-09-2011 05:00 |
N70- charging problem solution BY :sonojee | sonojee | Nokia Hardware & Hardware Repair | 0 | 07-28-2009 15:29 |
N70- charging problem solution BY :sonojee | sonojee | Nokia Hardware & Hardware Repair | 0 | 07-28-2009 15:28 |
NsPro Problems-Solutions | DIGITAL BABU | NSPRO | 3 | 10-13-2008 10:34 |
