Paused by temperature What is this problem, it always come up when i plug the charger to the phone... :confused: |
hey, that problem most common in v200. it makes it difficult to power on and power off most times. well rehot v100 i.c. and problem solved. if not then replace the i.c. ;) |
Thanks mate, it is true, its difficult to turn ON... But can show me where it is located on the PCB? |
1 Attachment(s) Not enough clear things here... 1.What handset? 2.If it's v200, here's the screenshot. 3.You probably thought of u100 (pw supply), v100 doesn't exist. 4.Check the pcb for water damage first..... br |
need to know abt C100's "Paused By Temperature" |
@amir for c100 chek LTRD if its ok , pz. flash the phone and rewrite iemi with the help of winiemi. |
In my case, reballing of flash IC solved the problem. br |
i change U100 reflash phone change imei flash init not result ______________________ any ideas ? |
Try changing system connector. |
a mor explanation please !!!!! |
system conector i check first - all ok |
Paused By Temperature - Samsun V200 I have a Samsung V200 phone which won't charge. I get the error above I have read a few posts which say resolder U100 (or v100?) . I ave also found a schematic on one of the posts. Before I do anything Can someone provide me with a recommended list of actions to follow i.e. do I need to flash te phone again, etc thanks PS If I need to change this v100 chip, were can I et a replacement |
hi u just rehot U100 and i remov small bateri near ic :rolleyes: not ( v100) i resolved this problem last days worcking perfect for me ! :D:) |
D410 HAS THE SAME PROBLEM. Tried to re-flow power IC but still same problem. Any other solution? tonytony |
Maya Plz Define Here Which Part Near The Ic {or Remove Cell ?}plz Explain I Dont Undersatnd Yet {if Its Not A V100 Fault Than Which Part U Changed Plz Define Beacuse Lot Of Beignner Are Reading Ur Post And Ur Solution They Didn't Understand Like Me |
