06-28-2007, 21:38 | #1 (permalink) |
Junior Member Join Date: Nov 2006 Location: marocco Age: 39
Member: 384581 Status: Offline Thanks Meter: 1 | problem with samsung d500 when you try to charged is get in hot please help me thank you in advence |
07-06-2007, 14:30 | #2 (permalink) |
Crazy Poster Join Date: Aug 2005 Age: 64
Member: 170987 Status: Offline Thanks Meter: 2 | hot i had same problem the speaker wire was dry solder joint i re heat and all ok also i cleaned lcd board and main board with solvent them dried and its all ok now gud luk. |
solution to " request error" when you try flashing | santaeufemia | Z3X-Team Products | 2 | 12-10-2009 16:16 |
always get error when i try to flash 706sc | rajan nishchal | Z3X-Team Products | 1 | 05-04-2009 21:06 |
Strange Problem with Blackberry 8700c when i try to re-flash after unlocking with MML | Boshko_Alfa | BlackBerry (RIM) | 0 | 04-01-2009 10:57 |
s100 shows temperature failure when try to charge | DaChecker | Samsung Hardware Repair | 0 | 05-05-2007 14:48 |
problem with Eric 1018. It shows full network, but when I try to call, it goes down | sat | Sony Ericsson Hardware Repair | 1 | 08-15-2001 10:36 |
