09-01-2015, 14:28 | #5 (permalink) |
No Life Poster Join Date: Mar 2003 Location: INDIA Age: 57
Member: 25662 Status: Offline Thanks Meter: 190 | Yes I know that problem is of lcd light but untill unless all connection of is not ok than led 20v volts will not fire or on. And in your given picture lcd volts both lines connected to tsp_scl (BSC4_scl)and tsp_sda (BSC4_sda).If disp_3.3v by mistake connected to tsp_sda than its possible that tsp_sda line gets fail for ever because its pull up volt is 1.8v. So that's why I edited it that nobody suffer. my intention was not to hurt you. I know you are more knowledgeable than me. |
09-29-2015, 07:54 | #6 (permalink) |
Freak Poster Join Date: Apr 2008 Location: India
Member: 745934 Status: Offline Thanks Meter: 41 | I think this diagram is NEO I9060 but shabeermobile needs I9060I (Neo Plus). I saw the connector ways, it is different Untitled-1.jpg |
10-04-2015, 06:53 | #9 (permalink) |
Member: 25662 Status: Offline Thanks Meter: 190 | [QUOTE=aliarjun;11315015]I think this diagram is NEO I9060 but shabeermobile needs I9060I (Neo Plus). I saw the connector ways, it is different QUOTE] compare all pin (lines) meter reading with I9060. Datalines, volts, ground. |
10-26-2016, 22:48 | #12 (permalink) | |
No Life Poster Join Date: Mar 2008 Location: Chittagong, Bangladesh. Age: 39
Member: 734476 Status: Offline Sonork: 100.1604415 Thanks Meter: 2,485 | Quote:
Today Solve my same Problem GT-I9060i/DS My Problem Is Yellow Connection Short I remove This capacitor https://photos.google.com/search/_tr...AWo7IekVXDhvEk | |
10-28-2016, 08:11 | #13 (permalink) |
Junior Member Join Date: Oct 2012 Location: Africa
Member: 1825090 Status: Offline Thanks Meter: 0 | Hi, please i have a samsung GT-i9060I/DS. When i power it ON, it comes on (for few seconds) shows the name of the phone and fades out/power down. if i try to power it ON again, it won't ON until i re-insert the battery. If i try to charge it, it shows battery with lightening sign in it (for few seconds also) then fades out. Please, i need help on what to do. Thanks |
