11-04-2004, 05:34 | #1 (permalink) |
No Life Poster Join Date: Sep 2002 Location: max232 chip
Member: 16036 Status: Offline Thanks Meter: 5 | r220 Network problem i have FEW r220 they SHOW FULL SIGNAL but when we dial out "CALLED FAILED" phones 100% legal can some1 TELL ME EXACTLY where problem aly which ic thanks alot bye |
11-06-2004, 11:09 | #6 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Gujranwala Pakistan Age: 48
Member: 71190 Status: Offline Sonork: 100.1580485 Thanks Meter: 87 | its simple byepass the 2 risesters down side of pa and up side of pa with a wire upside resesters r seres in antena swich . and cleen your set with ctc. your set will ok ( sorry my poor english) |
11-06-2004, 16:23 | #8 (permalink) |
Freak Poster Join Date: Feb 2004 Age: 56
Member: 52884 Status: Offline Thanks Meter: 13 | you should change th PA,if you remove the PA and insert a simcard and dial,it will say call fail,to me it is the PA.also to the last contributor to tell us the resistor that he is talking about.the number for the resistor,so that we that also try is own method . |
11-09-2004, 16:23 | #9 (permalink) | |
Insane Poster Join Date: Nov 2004 Location: Viet Nam Age: 47
Member: 89673 Status: Offline Thanks Meter: 0 | Quote:
11-12-2004, 03:22 | #10 (permalink) |
Freak Poster Join Date: Oct 2004 Location: TUNISIA Age: 44
Member: 85312 Status: Offline Sonork: 1576920 Thanks Meter: 35 | 1 - make full eeprom reset with code *2767*..... 2 - remove the antenna and try to call 4 - lock at the secondary antenna inside the antenna connecter if is good soldered 3 - if not calling change the pa good luck |
R220 Network problem | de brain box | Samsung Hardware Repair | 2 | 08-12-2007 11:52 |
r220 network problem | segun | Samsung Hardware Repair | 32 | 10-17-2006 07:03 |
Network Problem with R220 | Erebi | Samsung Hardware Repair | 0 | 08-01-2006 09:41 |
please helllp r200,r210,r220 network problem | segun | Samsung Hardware Repair | 0 | 05-03-2005 01:12 |
samsung R220 network problem??? | RAHUL12345 | Samsung Hardware Repair | 4 | 05-23-2004 15:20 |
