05-24-2016, 18:47 | #1 (permalink) |
Insane Poster Join Date: Mar 2013
Member: 1909191 Status: Offline Thanks Meter: 3 | s3 mi gt-i8190n imei null baseband unknow no cp I need your help I've a gt-i8190n with problem imei null & baseband unknown. It's no root and status official . Firmware and recovery stock. S/N is ok. Imei and ImeiSv are unknowed. pressing *#1234# i've as software status only ap and csc. No cp (black space) as screen shot attached. How to fix it? is it a problem hardware (of the ic modem)? thanks! |
05-31-2016, 21:18 | #4 (permalink) |
Member: 1909191 Status: Offline Thanks Meter: 3 | sorry sir but if the baseband is unknows for software problem i'd have cp: XXX calling *#1234#. is it right? i've not version info of cp as if the processor not reads the info. In the case is the hardware problem or you think software? i reflash with odin the stock firmware but it's the same |
06-01-2016, 03:33 | #5 (permalink) |
Junior Member Join Date: May 2016
Member: 2575859 Status: Offline Thanks Meter: 2 | Try to flash it again with 4 files Rom,this phone might lose cert file or flashed wrongly,if there was something wrong with processor as a hardware the phone initially wouldn't be up. |
06-18-2016, 18:48 | #6 (permalink) |
Member: 1909191 Status: Offline Thanks Meter: 3 | can you tell me where i can download europe firmware with 4 files rom and certificate file? if the gsm antena's damaged i'd have this problem? where's the gsm antena? is the lower one , seen by removing the back cover ? |
06-23-2016, 11:39 | #8 (permalink) |
Insane Poster Join Date: Sep 2015
Member: 2458311 Status: Offline Thanks Meter: 20 | Already i have seen this problem another device ,when they got a water damage .And if i washed in IPA (IzoPropil Alcohol) And warmed 250-300 celsius ,the Modem part come back ,and it was the original imei . |
06-23-2016, 12:13 | #9 (permalink) | |
Member: 1909191 Status: Offline Thanks Meter: 3 | Quote:
the picture of antenna shows that the antenna has been punctured ... can I repair it or needs to be replaced ? is the GSM antenna? the problem may depend on this antenna over the reader sim ,also? should rebuild pitches sim reader or make the jumpers ? wifi and bt work. thanks . | |
The Following User Says Thank You to bollicine For This Useful Post: |
06-30-2016, 15:35 | #10 (permalink) |
Member: 1909191 Status: Offline Thanks Meter: 3 | is it right? if i don't wrong the scheme, icp300 is signed as the picture please show this video... same problem! https://*y*outu.be/QaceoKZN7VE |
