Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 09-09-2014, 14:26   #1 (permalink)
karabey's Avatar
Member: 45183
Thanks Meter: 472
Exclamation s3 mini i8190 no pc connection
is there any solution for that problem'?i have change the port but same problem its charging but not connecting to pc (not installing driver)
Old 09-10-2014, 00:45   #2 (permalink)
Member: 1869842
Sonork: 100.1625473
Thanks Meter: 140
1- try to rehot osc200 & osc400
2-try to rehot u406 & ucp300
3- replace osc 200 & osc400
4- replace u406 & ucp300
don't forget to press thanks....
Old 09-10-2014, 14:04   #3 (permalink)
karabey's Avatar
Member: 45183
Thanks Meter: 472
now its says unknown device connected....what to do now?
Old 09-11-2014, 16:06   #4 (permalink)
Member: 1869842
Sonork: 100.1625473
Thanks Meter: 140
select computer on your desktop
right click on computer
select manage
select device manager/////pc
click scan for hardware changes
if you have windows 7 it should install automaticly
if the probleme remains install samsung kies software
Old 09-14-2014, 13:32   #5 (permalink)
karabey's Avatar
Member: 45183
Thanks Meter: 472
I zhink its a hardware problem. Is there any other solution
Old 09-14-2014, 17:12   #6 (permalink)
Member: 1869842
Sonork: 100.1625473
Thanks Meter: 140
the first quote i give you is the hardware solution
Old 09-14-2014, 18:50   #7 (permalink)
Member: 228508
Thanks Meter: 55
Phone is download mode
plug the USB cable
Pc unknow device phone problem
Pc samsung device connected spt patch flashing
Usb connecting ok
Old 09-14-2014, 19:38   #8 (permalink)
Member: 1869842
Sonork: 100.1625473
Thanks Meter: 140
plug the USB cable
Usb connecting ok
Is your probleme is solved??????.......than press thanks botton
Powered by Searchlight © 2017 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
Page generated in 0.34273 seconds with 8 queries
