Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 12-08-2004, 01:20   #1 (permalink)
kham's Avatar
Member: 3026
Sonork: 100.1602750
Thanks Meter: 102
S300 no power with LCD
hello
i have one s300 seem dead but when you remove lcd
the phone could power on
i think is a short circuit
i try with new ribbon ->same pb
need a solution
please help
Old 12-08-2004, 01:51   #2 (permalink)
Member: 95872
Originally Posted by kham
hello
need a solution
please help
try it with a working LCD from another phone...if it does the same ...please make sure your battery is ok ...the LCD draws a lot of power due to the backlight. If its not the battery then ...may the force be with U its a hardware problem on the PCB..in that case I would look at the power supply cirquit again.
Old 12-08-2004, 01:58   #3 (permalink)
kham's Avatar
Member: 3026
Sonork: 100.1602750
Thanks Meter: 102
ok
i will check the power ic
Old 01-21-2005, 11:42   #4 (permalink)
Member: 83893
any luck? I am facing the same prob....backlight of the lcd was off then tried some soldering of joints on the bottom of the lcd and then phone turned off permanently... probably i have s/c something instantly and now phone doesn't turn on... what do you suggest? checked fuse..
Service manual says that i should check the bridge on the lcd connector but dont which part is that....
Old 01-21-2005, 12:19   #5 (permalink)
Member: 60417
I think LCD is just damajed or wet. Also check it for shorts
Old 01-22-2005, 18:10   #6 (permalink)
kham's Avatar
Member: 3026
Sonork: 100.1602750
Thanks Meter: 102
i change with a new lcd
same pb
E251 no power when lcd light is off kabiyal UST Pro II 2 09-30-2010 07:59
No Power With Ufs Cable 3310 pankaj4u Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 03-20-2006 19:40
Big problem with 2 x E850 hang up and no power with button gilsie Trident/AGERE Platform 3 01-23-2006 06:37
s300 no power on!!!! lucik Samsung Hardware Repair 4 04-25-2005 15:52
Samsung S300 no power defender007 NSPRO 0 04-08-2005 18:12
Page generated in 0.15239 seconds with 9 queries
